Magpie ?
Posted: Fri Dec 16, 2005 8:55 am
by Gerusalem
need info on making a switch data file for moho
cant seem to make a switch file
Posted: Fri Dec 16, 2005 5:24 pm
by Lost Marble
Look in the Moho manual, Appendix section, "Magpie Setup". Magpie Pro has built-in support for Moho, but for the regular Magpie you need to define a custom output format.
Posted: Fri Dec 16, 2005 8:15 pm
by Gerusalem
done that the only thing im confused with is
after file is saved its not a switch file.
it has to be something ive done wrong
ive narrowed it down to when i save the magpie work into moho
at user define form its not going into switch data file
i filled out the format boxes like the tuteral 5.2 sayes
fustrated.......lol
Posted: Fri Dec 16, 2005 8:53 pm
by Lost Marble
When you save the file, put ".dat" at the end of the filename. So, instead of "myfile", you would save "myfile.dat".
If that doesn't do it, try opening the file in Notepad (it's really just text anyway). What does it look like in Notepad?
Posted: Sat Dec 17, 2005 4:36 am
by Gerusalem
Thanks it worked !
I hope this saves someone time
Good imagination no computer skills.
