Memory crash.
Posted: Mon Aug 17, 2015 5:19 pm
by sargumphigaus
So am I the only one who reaches a memory barrier with this program constantly? Like, if you put a certain level of detail into an animation, it basically crashes on you because it can't handle it? I've been having this problem for a long time now, and it's driving me insane.
Re: Memory crash.
Posted: Mon Aug 17, 2015 5:25 pm
by sargumphigaus
no seriously, all i'm doing is changing the layer order, and it crashes. I don't know what to do anymore. This is a brick wall to progress. if anyone knows if this even IS a memory related issue, or whatever it is, I would be eternally grateful if you could tell me how to prevent this from happening.
edit: On second thought, screw it. I'm just going to video layer it into existence. Last time I tried this, the software distorted everything. but evidently, this is the only way.
Re: Memory crash.
Posted: Mon Aug 17, 2015 5:49 pm
by funksmaname
is the problem your computer? could you share the file to see if moving the layer crashes the app elsewhere?
It may be a bug - in which case steps to reproduce it need to be established so it can be reported.
Re: Memory crash.
Posted: Mon Aug 17, 2015 6:09 pm
by sargumphigaus
funksmaname wrote:is the problem your computer? could you share the file to see if moving the layer crashes the app elsewhere?
wouldn't know the first thing about how to share a file. Either way, it looks like 11 took care of the issue of render distortion when it comes to combining layers with videos. So I think that this will have to be my solution. worse comes to worse, I can hide the distortion with a film grain effect.
Re: Memory crash.
Posted: Tue Aug 18, 2015 12:15 am
This is all strange to me, as I've had no worse experiences with AS than the occasional crash when I try to render a scene - no data loss ever. I just restart AS, open the scene, and it renders. But my animation is heavy on the image and video side, not in vectors, and I'm not using dynamics or physics or smart bones (yet).
Re: Memory crash.
Posted: Tue Aug 18, 2015 11:58 am
Same here. I can pick on a number of things in ASP but its memory handling hasn't been one of them. In fact, I've been surprised to be able animate certain data and rigs with it that would make After Effects cry.
Are you running the x64 version? If not, Anime Studio might not be using all of your available RAM. (My understanding is that the x32 software will only use up to 4 GB in an x64 OS.)
G.
Re: Memory crash.
Posted: Tue Aug 18, 2015 1:51 pm
by sargumphigaus
Oh it's 64 bit. Memory is a funny thing in this program. I can push it to levels of absurdity, but when it comes to shifting data orders, well forget it. Everything is out the window. Meanwhile, I can overload it in all other departments, just not in that particular department. In that department, layer arrangement just melts the software. I guess it is handling a lot of data and just overloads. Regardless, here's the trick.
render the layers seperately and then import the video with the file tab, and just layer over the video. Problem is completely solved, AND you can go above and beyond what you thought was originally possible. Just keep a sharp eye on the quality of the rendered videos as you progress.
Re: Memory crash.
Posted: Tue Aug 18, 2015 2:12 pm
Okay, I see what you mean.
I'm always rendering with Comp Layers for compositing so I guess I'm kinda doing the same thing anyway.
G.
Re: Memory crash.
Posted: Sun Aug 23, 2015 6:01 am
by lukejeans
how much RAM does your computer have?
