Can't leave advanced style mode
Posted: Tue Jun 23, 2015 6:03 pm
by jercook
I have a dilemma. While studying styles in as11 I changed to advanced mode and now can't see advanced button to return to normal. Program overfills screen area. Tried playing with monitor resolution, etc in order to display it but control seems to be below visible area. Also, when doubleclicking layers, to get layer properties, the cancel and ok button or below visible area of screen. Any ideas?????
is there a keyboard shortcut to control advanced mode of styles dialog????
Thanks,
Jerry
Re: Can't leave advanced style mode
Posted: Tue Jun 23, 2015 6:10 pm
by Víctor Paredes
Try undocking the Style window (Ctrl+Alt+Shift+Y). Maybe your screen doesn't support the minimum resolution required to run AS.
Posted: Tue Jun 23, 2015 6:26 pm
by jercook
That did the trick. thanks for the tip Victor. I'm running a resolution of 1920x1080 on my main monitor and1920x1080 on the 2nd monitor which is where that was. Thanks for your help! Apparently even my main monitor isn't hi enough resolution. It let me go to a separate window though so I guess I'm in business
Jerry
Posted: Tue Jun 23, 2015 6:36 pm
by Víctor Paredes
No, there shouldn't be any problem with your monitor. I'm on a 1366x768 screen and everything works fine.
