My name is Ralph and I'm a graphic designer/PT film maker. I just got the demo of MOHO, and am very impressed. I'm working on a full-length feature and am as impressed with the cost of the full version.
Just wanted to intoduce myself,
Ralph
Not in the same sense as flash.doomsdaydvd.com wrote:So, there aren't "symbols," then?
If you save your character in a separate file, you can import it into other files, and accomplish about the same thing.doomsdaydvd.com wrote:Or is there an easy way to use the same "character" over and over again?
Yup, keyframes are standard and moho will handle all the tweening.doomsdaydvd.com wrote:I guess I'd just modify the original file over and over again if I wanted to re-use the same character. Does the program use "keyframes" with "tweening" - or does it just follow what you've done at certain frames and assume a tweening instance for you?
Have a look in the Object Library directory/folder for examples of Moho "libraries".doomsdaydvd.com wrote:So, there aren't "symbols," then?
You can import any top layer (and its sub-layers) from any .moho file - good for backgrounds, props, character parts (such as the sample mouth sets) and fully rigged characters.doomsdaydvd.com wrote:Or is there an easy way to use the same "character" over and over again?
You can do it that way too if you wish.doomsdaydvd.com wrote:I guess I'd just modify the original file over and over again if I wanted to re-use the same character.
Anything you do at a certain frame creates a keyframe automatically on the timeline. Smooth tweening is the default interpolation from one keyframe to the next (there are other interpolation alternatives like ease in, ease out, ease in/out, linear) . Step interpolation is the same as no tweening - one position is held until the next keyframe, then it snaps to the next position.doomsdaydvd.com wrote:Does the program use "keyframes" with "tweening" - or does it just follow what you've done at certain frames and assume a tweening instance for you?
The tutorials are an excellent introduction to the basics of using Moho. They will help you get up to speed very quickly (if you do them, not just read them).doomsdaydvd.com wrote:It's weird - I just need to do the tutorials.
Slight jargon mismatch.doomsdaydvd.com wrote:I grab a hold of the shape selection tool, and it doesn't move anything.
Alas, gradients (and a number of other render-based effects, such as soft-edges) only show up when you render a frame or export an animation.doomsdaydvd.com wrote:I also tried to apply a gradient to a shape, and although the shape is labeled with a gradient, I don't see it.
