Text bending when following a path
Posted: Fri Jan 23, 2015 11:05 am
by JSD
I understand from the Anime Studio 10 manual that text can be made to bend when following a path by pressing the 'alt' key when using the 'follow path tool'. I have tried it without 'rotate to follow path' ticked in the layer settings and with. I have also tried with 'allow animated layer effects' ticked and unticked. I have tried with all combinations of these settings and still I can't get the text to 'snake' or 'bend'. It will follow the path. It will rotate as a text block as it follows the path, but it will not snake /bend. Would be grateful for advice on how I could achieve this effect.
Re: Text bending when following a path
Posted: Fri Jan 23, 2015 11:23 am
by JSD
I've just found the answer to my question - the text layer needs to be converted to a vector layer. Also ensure that there are no keyframes on the timeline that were placed there without the alt key pressed.
