Bezier curve editing for layer transforms
Posted: Wed Nov 05, 2014 12:49 pm
by thudjie
I have a layer which I transform and when I set the interpolation type to bezier I do not see any control handles for editing the curvature in the motion graph.
Am I missing something or is bezier only supported for bones?
Thanks
Re: Bezier curve editing for layer transforms
Posted: Wed Nov 05, 2014 2:57 pm
by hayasidist
uh? works fine here... are you sure you've ...
- set the layer transform keys to Bezier? (do they show with a dot in the middle of the key circle in channel view?) (and not only set default interp to Bezier which won't change existing interp modes)
- double clicked the relevant channel in motion graph view? (e.g. a translate will give you, initially, a brown curve then when you open it you get three curves - one each for x,y,z - red, green, blue)
if you're still having problems - just say and I'll have another look
Posted: Wed Nov 05, 2014 3:38 pm
by thudjie
Ah that was it!
I didn't realise you could double click to get the values for each axis.
That makes sense.
I'm still learning/new to AS (as you can tell!)
Thanks a lot.
Posted: Wed Nov 05, 2014 10:22 pm
by hayasidist
you're welcome - glad to help. And welcome to the forum BTW.
Posted: Thu Nov 06, 2014 7:28 pm
by thudjie
Thanks - I'm having a lot of fun with this software!
Posted: Mon Mar 02, 2015 5:24 pm
by Nicohk92
About motion gaph, when I have the bezier controls for x y and z, I can't figure out how to grab and control all simultaneously. I'm trying to smooth out a scaling move so I want my changes to be done proportionally on all axis and not have to adjust each separately and run the risk of being imprecise.
Is that possible?
