Double image when I render...???
Posted: Mon Apr 28, 2014 9:41 pm
by TheLankyLefty
Good day all.
I'm new to Anime Studio. I've created several characters so far. For all of them, when I'm checking out how it would look (control R) I am getting a double image. Why is this and what can I do to fix it? Thanks in advance.
Re: Double image when I render...???
Posted: Mon Apr 28, 2014 9:55 pm
by TheLankyLefty
Thought of another question. Yes....very new.... :shock:
I have switch layers for hands. Why is it that when I switch from a "pointing hand" to a "closed fist", it doesn't save to the mainline?
Posted: Mon Apr 28, 2014 10:55 pm
by Genete
TheLankyLefty wrote:Good day all.
Be sure you don't have motion blur enabled.
Posted: Tue Apr 29, 2014 12:03 am
by Lukas
Also, check your project settings if you have stereo rendering enabled. (It should be disabled if you want a single image).
TheLankyLefty wrote:Thought of another question. Yes....very new.... :shock:
Right click the switch layer and select the layer from the menu, instead of simply going to the layer. (Not sure if that was the problem, but it might have been..)
You can also, control+alt (or command+alt on mac) click on the hand in the viewport and select from the menu.
They keyframe will appear on the switch layer's timeline.
Posted: Tue Apr 29, 2014 10:19 am
by TheLankyLefty
I'll check all of those. Thank you very much!
This software is so robust that it's almost overwhelming.
I'll report back.
Posted: Wed Apr 30, 2014 1:54 pm
by TheLankyLefty
Thank you SOOOO much Lucas. Those were super simple fixes. You were correct about both of those.
I was about to pull my hair out over them. It's hard finding the simple things like that in the tutorials.
Many thanks!
