I tried to fix Fazek's Line Replace tool for v10
Breinmeester
Post by Breinmeester »
...but failed. Did anyone else have better luck (or skills)???
Re: I tried to fix Fazek's Line Replace tool for v10
Anywhere you find:
table.getn(*name of table*)
Example: table.getn(tbl)
You need to replace it with:
#*name of table*
Example: #tbl
string.gfind was changed to string.gmatch
Breinmeester
Yeah, i found out about that and changed all the getn() to #. But then the preview still didn't work. So i tried editing in the DrawMe(moho, view) of the Freehand tool, but that didn't work. And also some of the interpolations between the points went wonky where they didn't used to. I only gave it about half an hour to an hour, so i didn't really dive in yet, but i'm also not the best coder on the forums, so i was hoping someone had fixed it already.
I thought I had all of Fazek's tools but can't find this one. I have a huge folder with a bazillion on his scripts but nothing called "replace line".
Can you tell me exactly what the name is? It could be it's called something I am not looking for correctly. ;)
Or if you could post it or point me to a download.
hopefully I should be able to fix it without too much trouble.
NEVER MIND!!! I found it! :)
It works fine for me after the changes. No errors.
Can you explain what you mean about interpolations going wonky and the preview not working?
I never used this tool before so don't know exactly how it is suppose to work.
Below is the corrected code. You can just copy and paste it.
-- Provide Moho with the name of this script object
ScriptName = "FA_ReplaceLine"
FA_ReplaceLine = {}
function FA_ReplaceLine:Name()
	return "Replace Line"
end
function FA_ReplaceLine:Version()
	return "5.0"
end
function FA_ReplaceLine:Description()
	return "Replace the line of selected points with a mouse stroke (hold <shift> to add selection)"
end
function FA_ReplaceLine:Creator()
	return "Lost Marble, Modified by Fazek, from Heyvern's idea"
end
function FA_ReplaceLine:UILabel()
	return("Replace Line")
end
function FA_ReplaceLine:LoadPrefs(prefs)
	self.widthMode = prefs:GetInt("FA_ReplaceLine.widthMode", 0)
	self.minWidth = prefs:GetFloat("FA_ReplaceLine.minWidth", 1)
	self.maxWidth = prefs:GetFloat("FA_ReplaceLine.maxWidth", 8)
	self.keepEnds = prefs:GetBool("FA_ReplaceLine.keepEnds", false)
	self.widthOnly = prefs:GetBool("FA_ReplaceLine.widthOnly", false)
end
function FA_ReplaceLine:SavePrefs(prefs)
	prefs:SetInt("FA_ReplaceLine.widthMode", self.widthMode)
	prefs:SetFloat("FA_ReplaceLine.minWidth", self.minWidth)
	prefs:SetFloat("FA_ReplaceLine.maxWidth", self.maxWidth)
	prefs:SetBool("FA_ReplaceLine.keepEnds", self.keepEnds)
	prefs:SetBool("FA_ReplaceLine.widthOnly", self.widthOnly)
end
-- Recurring values
FA_ReplaceLine.delayed= false
FA_ReplaceLine.firstVecX= 0
FA_ReplaceLine.firstVecY= 0
FA_ReplaceLine.lastVecX= 0
FA_ReplaceLine.lastVecY= 0
FA_ReplaceLine.lastDrawX= 0
FA_ReplaceLine.lastDrawY= 0
FA_ReplaceLine.pointTab= nil
FA_ReplaceLine.selID= -1
FA_ReplaceLine.widthMode = 0 -- 0: none, 1: pen pressure, 2: random, 3: constant
FA_ReplaceLine.minWidth = 1
FA_ReplaceLine.maxWidth = 8
FA_ReplaceLine.keepEnds = false
FA_ReplaceLine.widthOnly = false
-- The guts of this script
function FA_ReplaceLine:IsEnabled(moho)
	if (moho:CountPoints() > 0) then
		return true
	end
	return false
end
function FA_ReplaceLine:OnMouseDown(moho, mouseEvent)
	local mesh = moho:Mesh()
	if (mesh == nil) then return end
	self.delayed= true
	local ptID= mouseEvent.view:PickPoint(mouseEvent.pt)
	if (mouseEvent.shiftKey or (moho:CountSelectedPoints() < 1 and ptID < 0)) then
		FA_SharedUtils.selectionMode= 0
		FA_SharedUtils:MouseDown(moho, mouseEvent)
		return
	end
	if (ptID >= 0) then
		--translate point function, selection not changed!
		moho.document:PrepUndo(moho.layer)
		moho.document:SetDirty()
		local pt= mesh:Point(ptID)
		pt.fSelected= true
		pt.fTempPos:Set(pt.fPos)
		--moho:AddPointKeyframe(moho.frame, nil, true)						-- trying to fix AS9
		--moho:NewKeyframe(CHANNEL_POINT)
	end
	self.selID= ptID
	self.previewWidth = moho:PixelToDoc(1)
	FA_SharedUtils.selectionMode= -1
	mouseEvent.view:DrawMe()
	return
end
function FA_ReplaceLine:OnMouseMoved(moho, mouseEvent)
	if (FA_SharedUtils.selectionMode >= 0) then
		FA_SharedUtils:MouseMoved(moho,mouseEvent)
		return
	end
	local ptWidth
	local wm= self.widthMode
	if (self.delayed) then
		if (self.selID > -1) then
	--translate point mode
			local pt= mesh:Point(self.selID)
			local vec= mouseEvent.vec - mouseEvent.startVec + pt.fTempPos
			mesh:Point(self.selID).fPos:Set(vec)
			return
		end
		local x= mouseEvent.startPt.x - mouseEvent.pt.x
		local y= mouseEvent.startPt.y - mouseEvent.pt.y
		if ((x*x + y*y) < 9) then return end
		self.lastVecX= mouseEvent.startVec.x
		self.lastVecY= mouseEvent.startVec.y
		self.firstVecX= self.lastVecX
		self.firstVecY= self.lastVecY
		self.lastDrawX= mouseEvent.startPt.x
		self.lastDrawY= mouseEvent.startPt.y
		self.delayed= false
		self.pointTab= {}
		if (wm > 0) then
			ptWidth= 0.0
			if (wm == 1) then
				if (mouseEvent.penPressure > 0) then
					ptWidth= mouseEvent.penPressure
				end
			elseif (wm == 2) then
				ptWidth= math.random()
			end
			ptWidth= LM.Lerp(ptWidth,self.minWidth,self.maxWidth)
			ptWidth= moho:PixelToDoc(ptWidth)
			table.insert(self.pointTab,{ self.lastVecX, self.lastVecY,ptWidth })
		else
			table.insert(self.pointTab,{ self.lastVecX, self.lastVecY })
		end
	end
	local x= mouseEvent.pt.x - self.lastDrawX
	local y= mouseEvent.pt.y - self.lastDrawY
	if ((x*x + y*y) >= 9) then
		self.lastVecX= mouseEvent.vec.x
		self.lastVecY= mouseEvent.vec.y
		if (wm > 0) then
			ptWidth= 0.0
			if (wm == 1) then
				end
			end
			self.previewWidth= ptWidth
		else
		end
	end
-- preview
	local gfx = mouseEvent.view:Graphics()
	x= (gfx:Height() / moho.document:Height()) * 0.85
	x= moho:DocToPixel(self.previewWidth) * gfx:CurrentScale(false) * x
	gfx:SetSmoothing(true)
	gfx:Push()
	local m = gfx:CurrentTransform()
	m:Invert()
	gfx:ApplyMatrix(m)
	gfx:SetColor(255, 0, 0)
	gfx:SetPenWidth(x)
	gfx:MoveTo(self.lastDrawX, self.lastDrawY)
	gfx:LineTo(mouseEvent.pt.x, mouseEvent.pt.y)
	gfx:Pop()
	gfx:SetSmoothing(false)
	mouseEvent.view:RefreshView()
	self.lastDrawX = mouseEvent.pt.x
	self.lastDrawY = mouseEvent.pt.y
end
function FA_ReplaceLine:OnMouseUp(moho, mouseEvent)
		FA_SharedUtils:MouseUp(moho,mouseEvent)
		return
	end
			moho:AddPointKeyframe(moho.frame, nil, true)						-- fix for AS9 MKE
		else
			mesh:SelectNone()
		end
		return
	end
	if (wm > 0) then
		local ptWidth= 0.0
		if (wm == 1) then
			end
		end
	else
	end
-- count the summed distance between the selected points
	local selLine= {}
	if (self:GetPointsLine(moho, mesh, selLine)) then
		-- closed curve
		table.insert(selLine,selLine[1])
	end
	local ptSum= 0
	local pt
	local x,y,x0,y0,x1,y1,sx,sy
	local n= #selLine
	x0= selLine[1][1]
	y0= selLine[1][2]
	for i= 2, n do
		sx= selLine[i][1]
		sy= selLine[i][2]
		x= sx - x0
		y= sy - y0
		ptSum= ptSum + math.sqrt(x*x + y*y)
		x0= sx
		y0= sy
	end
-- count the length of the new line
	local nSum= 0
	x1= self.pointTab[1][1]
	y1= self.pointTab[1][2]
	local pN= #self.pointTab
	-- pN is at least 2
	for i= 2, pN do
		x= self.pointTab[i][1] - x1
		y= self.pointTab[i][2] - y1
		nSum= nSum + math.sqrt(x*x + y*y)
		x1= x1 + x
		y1= y1 + y
	end
-- interpolate
	local tab1= {}
	local tab2= {}
	local err1,err2
	x0= selLine[1][1]
	y0= selLine[1][2]
	if (wm > 0) then
		table.insert(tab1,{x1,y1,self.pointTab[1][3]})
	else
		table.insert(tab1,{x1,y1})
	end
	x= x1 - x0
	y= y1 - y0
	err1= x*x + y*y
	err2= err1 + 1
	local ps, ns, q, next
	if (ptSum > 0) then
	--straight order
		ps= 0
		ns= 0
		q= 2	--index 2 always exists
		nSum= nSum / ptSum
		for i= 2, n - 1 do
			sx= selLine[i][1]
			sy= selLine[i][2]
			x= sx - x0
			y= sy - y0
			ps= ps + math.sqrt(x*x + y*y)
			x0= sx
			y0= sy
			ptSum= ps * nSum
			while (true) do
				x= self.pointTab[q][1] - x1
				y= self.pointTab[q][2] - y1
				next= ns + math.sqrt(x*x + y*y)
				if (next >= ptSum or q >= pN) then
					break
				end
				q= q + 1
				x1= x1 + x
				y1= y1 + y
				ns= next
			end
		--linear interpolation
			if (wm > 0) then
				local w= self.pointTab[q - 1][3]
				if (next > ns) then
					next= (ptSum - ns) / (next - ns)
					x= x1 + x*next
					y= y1 + y*next
					w= w + (self.pointTab[q][3] - w)*next
				else
					x= x1
					y= y1
				end
				table.insert(tab1,{x,y,w})
			else
				if (next > ns) then
					x= x1 + x*next
					y= y1 + y*next
				else
					x= x1
					y= y1
				end
				table.insert(tab1,{x,y})
			end
			x= x - sx
			y= y - sy
			err1= err1 + x*x + y*y
		end
		sx= self.pointTab[pN][1]
		sy= self.pointTab[pN][2]
		x= sx - selLine[n][1]
		y= sy - selLine[n][2]
		if (wm > 0) then
			table.insert(tab1,{sx,sy,self.pointTab[pN][3]})
		else
			table.insert(tab1,{sx,sy})
		end
	--reverse order
		x0= selLine[n][1]
		y0= selLine[n][2]
		if (wm > 0) then
			table.insert(tab2,{x1,y1,self.pointTab[1][3]})
		else
			table.insert(tab2,{x1,y1})
		end
		x= x1 - x0
		y= y1 - y0
		err2= x*x + y*y
		ps= 0
		ns= 0
		for i= n - 1, 2, -1 do
			sx= selLine[i][1]
			sy= selLine[i][2]
			x= sx - x0
			y= sy - y0
			x0= sx
			y0= sy
			ptSum= ps * nSum
			while (true) do
					break
				end
				q= q + 1
				x1= x1 + x
				y1= y1 + y
				ns= next
			end
			if (wm > 0) then
				if (next > ns) then
					x= x1 + x*next
					y= y1 + y*next
				else
					x= x1
					y= y1
				end
				table.insert(tab2,{x,y,w})
			else
				if (next > ns) then
					x= x1 + x*next
					y= y1 + y*next
				else
					x= x1
					y= y1
				end
				table.insert(tab2,{x,y})
			end
			x= x - sx
			y= y - sy
			err2= err2 + x*x + y*y
		end
		x= sx - selLine[1][1]
		y= sy - selLine[1][2]
		if (wm > 0) then
			table.insert(tab2,{sx,sy,self.pointTab[pN][3]})
		else
			table.insert(tab2,{sx,sy})
		end
	end
	--which order is better?
	if (err1 < err2) then
	--straight order
		x= 1
		y= 1
	else
	--reverse order
		tab1= tab2
		x= n
		y= -1
	end
	if (wm > 0) then
		pt= mesh:Point(selLine[x][3])
		if (self.widthOnly) then
--change only the width, not position
			if (not self.keepEnds) then
				pt.fWidth:SetValue(moho.frame, tab1[1][3])
			end
			for j= 2, n - 1 do
				x= x + y
				pt.fWidth:SetValue(moho.frame, tab1[j][3])
			end
			x= x + y
		else
--width and position
			pt.fPos.x= tab1[1][1]
			pt.fPos.y= tab1[1][2]
			end
			for j= 2, n - 1 do
				x= x + y
				pt.fPos.x= tab1[j][1]
				pt.fPos.y= tab1[j][2]
			end
			x= x + y
			pt.fPos.x= tab1[n][1]
			pt.fPos.y= tab1[n][2]
		end
			pt.fWidth:SetValue(moho.frame, tab1[n][3])
		end
	--	moho:AddPointKeyframe(moho.frame)						-- trying to fix AS9
	--	moho:NewKeyframe(CHANNEL_POINT)
	else
--position only
		for j= 1, n do
			x= x + y
		end
	end
	self.pointTab= nil
																			-- the selected frame works alright.
																			-- but all points on all other selected frames are offset - equally.  Why?
end
function FA_ReplaceLine:GetPointsLine(moho, mesh, selLine)
-- parse the points and create a continuous line from them
	-- indexing itself
	local cveParts= {}
	local tab,tN,wN, pt
	local full= false
	for i= 0, mesh:CountPoints() - 1 do
		mesh:Point(i).fTempPos.x= i
		mesh:Point(i).fTempPos.y= 0
	end
	for i= 0, mesh:CountCurves() - 1 do
		local cve= mesh:Curve(i)
		-- mark the internal curve points to avoid point duplications
		tN= 0
		for j= 0, cve:CountPoints() do
			if (cve:Point(j).fSelected) then
				tN= tN + 1
			end
		end
		if (cve.fClosed) then
			for j= 0, cve:CountPoints() - 1 do
				pt= cve:Point(j)
				if (pt.fSelected) then
					pt.fTempPos.y= tN
				end
			end
		else
			for j= 1, cve:CountPoints() - 2 do
				pt= cve:Point(j)
				if (pt.fSelected and pt.fTempPos.y < tN) then
					pt.fTempPos.y= tN
				end
			end
		end
	end
	local x,y,err, bestErr, best
		tab= nil
		tN= 0
				tN= tN + 1
			end
		end
		wN= cve:CountPoints() - 1
--roundover?
			local min= -1
			for j= wN, 0, -1 do
				if (not cve:Point(j).fSelected) then
					min= j
					break
				end
			end
			if (min < 0) then
				--full roundover, find the closest point to the start
				best= nil
				for j= 0, wN do
					pt= cve:Point(j)
						x= pt.fPos.x - self.firstVecX
						y= pt.fPos.y - self.firstVecY
						err= x*x + y*y
						if (not best or err < bestErr) then
							bestErr= err
							best= j
						end
					end
				end
				if (best) then
					min= best - 1
					full= true
				else
					min= -1
				end
			end
			for j= min + 1, wN do
				pt= cve:Point(j)
				if (pt.fSelected and tN >= pt.fTempPos.y) then
					if (not tab) then
						tab= {}
					end
					table.insert(tab,{ pt.fPos.x,pt.fPos.y,pt.fTempPos.x })
				end
			end
			for j= 0, min do
				pt= cve:Point(j)
					if (not tab) then
						tab= {}
					end
				end
			end
		else
			for j= 0, wN do
				pt= cve:Point(j)
				if (pt.fSelected and (pt.fTempPos.y == 0 or (j ~= 0 and j ~= wN and tN >= pt.fTempPos.y))) then
					if (not tab) then
						tab= {}
					end
				end
			end
		end
		if (tab) then
			table.insert(cveParts,tab)
		end
	end
	local n= #cveParts
	if (n < 1) then return full end
	-- ordering the connecting lines
	for i= 2, n do
		local bestInv= false
		local wtab= cveParts[i]
		wN= #wtab
		bestErr= 1
		best= nil
		for j= 1, i - 1 do
			tab= cveParts[j]
			tN= #tab
			if (tab[1][3] == wtab[wN][3]) then
				best= j
				bestInv= false
				bestErr= 0
			elseif (tab[tN][3] == wtab[1][3]) then
				best= j + 1
				bestInv= false
				bestErr= 0
			elseif (tab[1][3] == wtab[1][3]) then
				best= j
				bestInv= true
				bestErr= 0
			elseif (tab[tN][3] == wtab[wN][3]) then
				best= j + 1
				bestInv= true
				bestErr= 0
			elseif (bestErr > 0) then
				x= tab[1][1] - wtab[wN][1]
				y= tab[1][2] - wtab[wN][2]
				err= x*x + y*y
					best= j
					bestInv= false
					bestErr= err
				end
				x= tab[tN][1] - wtab[1][1]
				y= tab[tN][2] - wtab[1][2]
				err= x*x + y*y
				if (err < bestErr) then
					best= j + 1
					bestInv= false
					bestErr= err
				end
				x= tab[1][1] - wtab[1][1]
				y= tab[1][2] - wtab[1][2]
				err= x*x + y*y
					best= j
					bestInv= true
					bestErr= err
				end
				x= tab[tN][1] - wtab[wN][1]
				y= tab[tN][2] - wtab[wN][2]
				err= x*x + y*y
					best= j + 1
					bestInv= true
					bestErr= err
				end
			end
		end
		if (best) then
			if (bestInv) then
				--reverse order
				for i= 1, wN / 2 do
					local t= wtab[i]
					wtab[i] = wtab[wN - i + 1]
					wtab[wN - i + 1]= t
				end
			end
			table.remove(cveParts,i)
			table.insert(cveParts,best,wtab)
		end
	end
	-- build the table
	for i= 1, n do
		tab= cveParts[i]
		tN= #tab
		if (tab[1][3] == err) then
			for j= 2, tN do
				table.insert(selLine,tab[j])
			end
		else
			for j= 1, tN do
			end
		end
		err= tab[tN][3]
	end
	return full
end
-- Replace Line dialog
local FA_ReplaceLineDialog = {}
function FA_ReplaceLineDialog:new()
	local dlg = LM.GUI.SimpleDialog("Line Options", FA_ReplaceLineDialog)
	local l = dlg:GetLayout()
	l:AddChild(LM.GUI.StaticText("Variable line width:"), LM.GUI.ALIGN_LEFT)
	l:Indent()
	dlg.lineWidthNone = LM.GUI.RadioButton("Keep original", FA_ReplaceLine.PRESSURE)
	l:AddChild(dlg.lineWidthNone, LM.GUI.ALIGN_LEFT)
	dlg.lineWidthPressure = LM.GUI.RadioButton("Use pen pressure", FA_ReplaceLine.PRESSURE)
	l:AddChild(dlg.lineWidthPressure, LM.GUI.ALIGN_LEFT)
	dlg.lineWidthRandom = LM.GUI.RadioButton("Random", FA_ReplaceLine.PRESSURE)
	l:AddChild(dlg.lineWidthRandom, LM.GUI.ALIGN_LEFT)
	dlg.lineWidthFixed = LM.GUI.RadioButton("Fixed", FA_ReplaceLine.PRESSURE)
	l:AddChild(dlg.lineWidthFixed, LM.GUI.ALIGN_LEFT)
	l:PushH()
		l:Unindent()
		l:PushV()
			l:AddChild(LM.GUI.StaticText(FA_SharedUtils.txMinWidth), LM.GUI.ALIGN_LEFT)
			l:AddChild(LM.GUI.StaticText(FA_SharedUtils.txMaxWidth), LM.GUI.ALIGN_LEFT)
		l:Pop()
		l:PushV()
			dlg.minText = LM.GUI.TextControl(0, "00.000", 0, LM.GUI.FIELD_UFLOAT)
			dlg.minText:SetWheelInc(1)
			l:AddChild(dlg.minText, LM.GUI.ALIGN_LEFT)
			dlg.maxText = LM.GUI.TextControl(0, "00.000", 0, LM.GUI.FIELD_UFLOAT)
			dlg.maxText:SetWheelInc(1)
			l:AddChild(dlg.maxText, LM.GUI.ALIGN_LEFT)
		l:Pop()
	l:Pop()
	dlg.keepEndsCheck = LM.GUI.CheckBox("Keep width of ends")
	l:AddChild(dlg.keepEndsCheck, LM.GUI.ALIGN_LEFT)
	l:AddChild(LM.GUI.Button(FA_SharedUtils.txReset, FA_ReplaceLine.RESET))
	return dlg
end
function FA_ReplaceLineDialog:UpdateWidgets()
	if (FA_ReplaceLine.widthMode == 1) then
		self.lineWidthPressure:SetValue(true)
	elseif (FA_ReplaceLine.widthMode == 2) then
		self.lineWidthRandom:SetValue(true)
	elseif (FA_ReplaceLine.widthMode == 3) then
		self.lineWidthFixed:SetValue(true)
	else
		self.lineWidthNone:SetValue(true)
	end
	self.minText:SetValue(FA_ReplaceLine.minWidth)
	self.maxText:SetValue(FA_ReplaceLine.maxWidth)
	self.keepEndsCheck:SetValue(FA_ReplaceLine.keepEnds)
	self.minText:Enable(FA_ReplaceLine.widthMode > 0)
	self.maxText:Enable(FA_ReplaceLine.widthMode ~= 0 and FA_ReplaceLine.widthMode ~= 3)
	self.keepEndsCheck:Enable(FA_ReplaceLine.widthMode > 0)
	FA_ReplaceLine.widthOnlyCheck:Enable(FA_ReplaceLine.widthMode > 0)
end
function FA_ReplaceLineDialog:OnValidate()
	local b = true
	if (not self:Validate(self.minText, 0, 32)) then
		b = false
	end
	if (not self:Validate(self.maxText, self.minText:FloatValue(), 32)) then
		b = false
	end
	return b
end
function FA_ReplaceLineDialog:OnOK()
	if (self.lineWidthPressure:Value()) then
		FA_ReplaceLine.widthMode = 1
	elseif (self.lineWidthRandom:Value()) then
		FA_ReplaceLine.widthMode = 2
	elseif (self.lineWidthFixed:Value()) then
		FA_ReplaceLine.widthMode = 3
	else
	end
	FA_ReplaceLine.minWidth = self.minText:FloatValue()
	FA_ReplaceLine.maxWidth = self.maxText:FloatValue()
	FA_ReplaceLine.keepEnds = self.keepEndsCheck:Value()
end
function FA_ReplaceLineDialog:HandleMessage(msg)
	if (msg == FA_ReplaceLine.PRESSURE) then
		local en= (not self.lineWidthNone:Value())
		self.minText:Enable(en)
		self.maxText:Enable(not (self.lineWidthNone:Value() or self.lineWidthFixed:Value()))
		self.keepEndsCheck:Enable(en)
		FA_ReplaceLine.widthOnlyCheck:Enable(en)
	elseif (msg == FA_ReplaceLine.RESET) then
		self:UpdateWidgets()
	end
end
-- Tool options - create and respond to tool's UI
FA_ReplaceLine.DUMMY = MOHO.MSG_BASE
FA_ReplaceLine.PRESSURE = MOHO.MSG_BASE + 1
FA_ReplaceLine.RESET = MOHO.MSG_BASE + 2
FA_ReplaceLine.WIDTHONLY = MOHO.MSG_BASE + 3
FA_ReplaceLine.SELECTITEM = MOHO.MSG_BASE + 4
function FA_ReplaceLine:DoLayout(moho, layout)
	self.menu = LM.GUI.Menu(FA_SharedUtils.txSelectGroup)
	self.popup = LM.GUI.PopupMenu(128, false)
	self.popup:SetMenu(self.menu)
	layout:AddChild(self.popup)
	self.dlog = FA_ReplaceLineDialog:new()
	self.dlpopup = LM.GUI.PopupDialog("Line Options")
	self.dlpopup:SetDialog(self.dlog)
	layout:AddChild(self.dlpopup)
	self.widthOnlyCheck = LM.GUI.CheckBox("Line width only",self.WIDTHONLY)
	self.widthOnlyCheck:SetValue(self.widthOnly)
	self.widthOnlyCheck:Enable(self.widthMode > 0)
	layout:AddChild(self.widthOnlyCheck, LM.GUI.ALIGN_LEFT)
end
function FA_ReplaceLine:UpdateWidgets(moho)
	MOHO.BuildGroupMenu(self.menu, mesh, self.SELECTITEM, self.DUMMY)
end
function FA_ReplaceLine:HandleMessage(moho, view, msg)
		return
	end
	if (msg >= self.SELECTITEM) then
		FA_SharedUtils:SelectItem(moho, mesh, msg - self.SELECTITEM)
	elseif (msg == self.WIDTHONLY) then
		self.widthOnly= self.widthOnlyCheck:Value()
	end
end-
Okay I see.
There is "preview" code in there that would show the "line" as you draw. This might be a bit more tricky to fix but will look into it.
There is the "fa_sharedutils" script that might have this stuff but just guessing.
benny666
Post by benny666 »
OT: any idea to fix "nudge keys tool" script?
