Lava Lamp Effect
Posted: Fri Nov 15, 2013 6:17 pm
by DK
Hi.
I am working on a project where a character goes behind lettering that is filled with a lava Lamp effect. I need the characters silhouette or even the character's body to take on this effect where bits of him elongate and travel upwards. Any ideas how i might achieve this?
Many thanks for any suggestions.
D.K
Re: Lava Lamp Effect
Posted: Fri Nov 15, 2013 6:21 pm
Duplicates and masking using Mike's warp field trick:
viewtopic.php?t=1443
Posted: Sat Nov 16, 2013 2:18 am
I think you need to work in two steps.
First you animate the lava in the lamp: slowly drifting lumps etc.
Second you apply the character into this. I'd work with bitmaps and distort them with bones, but that's up to your taste.
Posted: Sat Nov 16, 2013 1:50 pm
by DK
Thanks guys.
I might to go look at some reference material on Lava Lamps then work from there keeping both your suggestions in mind.
Cheers
D.K
Posted: Mon Nov 18, 2013 5:26 pm
by GCharb
I'd simply make a lava lamp effect in Blender then use a mask, should be easy enough for you!
