AS Pro 9.1 delays when Start and End frames set to 0
Posted: Mon Oct 28, 2013 8:47 am
When I'm drawing I sometimes hit Spacebar accidentally, and before I know it I'm manipulating points on frame 100 instead of frame 0. I thought a genius way to avoid this would be to set the Start and End frames to 0 in the project properties. That way when I hit Spacebar nothing happens.
The problem with this is AS Pro becomes unresponsive for some reason. I'll click to select another layer and nothing will happen for 5 to 7 seconds. I'll use a File or Edit menu option and there is a 5 to 7 second delay before Undo, Redo, Save, etc. actually happens. Setting the Start and End frames back to numbers greater than 0 resolves this problem, and performance goes back to normal.
I'm using AS Pro 9.1 on OS X Mountain Lion. I tested starting in both 64-bit and 32-bit modes.
This sort of sounds like a bug of some sort, but I see now AS Pro is up to like 9.5 or something so maybe the problem no longer exists in the updated version. Can anyone confirm whether that is the case? I've been meaning to update AS and also OS X to Mavericks, but haven't had the time to look into any of that yet.
