Possible to create an action from timeline animation?
Posted: Thu Aug 08, 2013 2:45 am
by lehtiniemi
In AS9, is it possible to grab animation and make an action? Let's say I've already animated some walk cycle and want to make an action out of it. Is there a way to move the animation by for example copy-pasting the desired bits? How do you achieve this?
Re: Possible to create an action from timeline animation?
Posted: Thu Aug 08, 2013 5:18 am
by Lukas
You can create an Action and paste the Mainline in the Action. (In the same way you would copy an Action into the Mainline)
Posted: Thu Aug 08, 2013 5:53 am
by lehtiniemi
How do you do this? I try to select the keyframes in my mainline, hit "copy", then open the new empty action and hit paste but pasting isn't available.
Posted: Thu Aug 08, 2013 6:01 am
by Lukas
When you are inside the new empty action (A red arrow should be in front of the name of your action in the "Actions" window), select the "Mainline" (don't double click, because you'll enter the mainline again). And hit the 3rd button (it's called "Copy action") in the Actions window. It will put the entire mainline of your current layer (including child layers) in the action.
Now you have your entire animation in the action, even though you might only want a small part of it. Now use "Clear animation before/after current frame" to remove the parts you don't want in your action. And drag the part you want to keep to frame 1 (you don't want actions to start with a big void).
Posted: Thu Aug 08, 2013 6:05 am
by lehtiniemi
Ah, now I got it! So cool! Thank you so much!!!
Posted: Thu Aug 08, 2013 6:06 am
by Lukas
happy to help
Posted: Thu Aug 08, 2013 6:08 am
by lehtiniemi
This also seems to allow me to duplicate actions since you can pull the animation from other actions as well. Makes life so much easier. Thanks again!
Posted: Tue Oct 01, 2013 2:50 am
by Animark
Cool, this topic helped me a lot! Thanks!
Posted: Tue Oct 01, 2013 8:51 pm
by bubai
Thanks it's a great topic. Much appreciated.
