What is the procedure for adding text for a Title and also for credits?
Is this the right forum for this question?
Why is there air?
Newbe wants to make title and credits
The easiest way to do this is to use the credits script that comes with moho. It's under the "Scripts" menu, then "Other" -> "Credits..."
It will allow you to choose the font you'd like your credits rendered in.
It will ask you for a text file and use that file to create a sequence of slides with a screen for each section of text.
It will also use your current fg/bg settings for the color and outline of the letters.
Hope this helps,
jorgy
Hope this helps,
jorgy
Like Mr. Blaaa said, give it a try! You will have to experiment to get the sizes that you need for the font that you want. Also, try to keep it to just a few words wide if you want to be readable for smaller size animations.ingie01 wrote:jorgy,
thank you for the info. I was unsure where the text came from. So I can use windows note pad for the text file and Moho will through the "scripts" change it to a usable form?
ingie01
A blank line will indicate a break between "slides".
