Case of the Disappearing keyframes
Posted: Fri May 17, 2013 5:02 am
by DK
After having this happen for quite some time I finally decided to Wink it as proof i am not mad.
Behold the case of the mysterious disapearing keyframes!
http://www.polliefillers.com.au/ASbug/AsBug.htm
Anyone know why this is happening?
Cheers
D.K
Re: Case of the Disappearing keyframes
Posted: Fri May 17, 2013 6:06 am
I tried and tried to replicate this but I can't.
First I tried point keys. Then I tried the camera position keys like you have. I then shifted the layer. I also tried putting in the "whatsit thingy" repeat key thing (green on timeline forget what it's called). Does this happen all the time or only once in a while? What version are you using? Is it 9.2 or 9.1?
Posted: Fri May 17, 2013 8:53 am
by DK
Hi Vern.
Happens ALL the time.
It's pro universal 9.0. I might go get 9.2 and see if it's still doing it.
D.K
Posted: Fri May 17, 2013 8:58 am
by DK
Vern.
Here's the file if you think it might help.
http://www.polliefillers.com.au/ASbug/ASbug.zip
Cheers
D.K
Posted: Fri May 17, 2013 9:16 am
by DK
Update:
Just downloaded and installed ASPro 9.2 and the problem is gone.
Cheers
D.K
