blur the background
Posted: Sun Mar 17, 2013 4:39 pm
by skygaz3r
hello guys!
i was wondering if there is a possibility to blur a layer so it looks less "sharp"
and gets more this kind of "in the far background" look
Re: blur the background
Posted: Sun Mar 17, 2013 5:19 pm
by rocky53204
You might try enabling depth of field in project settings and then insuring z depth of your background layer is set back... let me know if this helps.
Posted: Sun Mar 17, 2013 6:45 pm
Use "blur" in layer properties. Tip: Render the result and re-import (and switch off the original BG layers), thus saving your computer processing power when rendering the animation.
Posted: Thu Mar 21, 2013 9:51 pm
by arfa
If it is an AS composite render the scene and use P'shop to blur. You might also want to add a few other touches and appreciate the extra control in P'shop [or Gimp or..] - *then* re-import.
Posted: Fri Apr 05, 2013 4:49 am
by SpaceBoy64
Also, in Layer Settings, you could enter a number in the Blur Radius box. If you want it to change during the animation, you could check the allow animated layer effects box and set keyframes for the value in the Blur Radius box.
