I created a character in anime studio 9 with full 3d capabilities I didnt back up the file and now it wont open instead I get an error message ...it says 'could not open error details:Read error at line 175948. In code file..\..\..\lib_moho\animvec2.cpp,line64
I was told I should try a text editor and see if any thing was wrong with line 175948 im kind of lost at this so if any one can help me it would be great .
here is the unfinished version I created before the error
http://www.youtube.com/watch?v=eaRj2DkH6Zk
PLEASE help with error HELP please!
marcushaskins@ymail.com
- ErikAtMapache
Re: PLEASE help with error HELP please!
Sorry but it's looking bad. The ".cpp" part of the file name means there is a bug in the program source code that is blowing up. First check the most obvious thing -- look at your windows explorer (or whatever the equivalent is for mac if you use that) and make sure the file size is not 0. If it is, there's nothing to recover. Next thing to check is that you did not accidentally move any of the 3d source files. A last attempt is to copy your file and see if the copy opens. You can try opening the AS file in a text editor (notepad or wordpad) but it looks pretty involved and you would probably end up spending more time debugging the file than just recreating the original. The only other thing I can think of is you are using the 32 bit version of the program (or are on Windows XP) and you made a super-huge file the blew-up the program (more than 2 gig in size). If that is the case, you need to scale back a bit.
Sorry I can't be of more help. Good luck.
Erik
Erik
Find me on Content Paradise at:
http://www.contentparadise.com/SearchRa ... xt=mapache
