UI Plug-in
Posted: Mon Jan 21, 2013 10:41 pm
by The80sKickAss
OK, so I know you can make Tool scripts and menu scripts but can you use Lua to make a UI component? As in an actual plug-in with it's own set of parameters and functionality; like something you would see in something like After Effects.
Re: UI Plug-in
Posted: Wed Jan 23, 2013 11:12 pm
by Breinmeester
If Moho was accessable in a non-modal window, users could script their own floating windows with functionality, much like the Actions or Styles window. Alas, it is not....
Re: UI Plug-in
Posted: Thu Jan 24, 2013 11:01 am
by videodv
Breinmeester wrote:If Moho was accessable in a non-modal window, users could script their own floating windows with functionality, much like the Actions or Styles window. Alas, it is not....
You would have to use wxLua for this, I have done a simple test and it worked fine but only in 32bit.
Regards
Chris.
Re: UI Plug-in
Posted: Thu Jan 24, 2013 11:18 am
by Breinmeester
Wow, sounds good! Can u share your findings and knowledge?
Re: UI Plug-in
Posted: Thu Jan 24, 2013 11:35 am
by videodv
You can find my simple test example in this link,
http://www.kelleytown.com/forum/animato ... erms=wxlua
If you wish to try download this zip
http://dl.dropbox.com/u/66269094/wx.7z you will have all you need to test out .
Remember this works on windows, And Anime Studio 32bit only.
Regards
Chris.
Re: UI Plug-in
Posted: Fri Jan 25, 2013 2:48 am
by Breinmeester
Thanks! That looks great!! I hope to play around with this as soon as i have time.
Re: UI Plug-in
Posted: Mon Jan 28, 2013 7:33 am
by Breinmeester
Ive tried out your example file. It's a little too slow for me. Also, it's a window outside of the programme. I don't think it's an appropriate solution for the fact that Moho isn't passed to a non-modal window. Make it happen lost Marble!
Re: UI Plug-in
Posted: Mon Jan 28, 2013 8:25 am
by videodv
Breinmeester wrote:I don't think it's an appropriate solution for the fact that Moho isn't passed to a non-modal window. Make it happen lost Marble!
Could'nt agree more lets hope it is not to far off.
Regards
Chris.
