Barber Pole
Posted: Thu Dec 20, 2012 6:58 pm
by msmart
I tried Masks, Switch Layers, Bones and finally used point anime very time consuming, Any one know of an eaiser more smooth way to create a Barber pole? As it is obvious mine is far from perfect. Made Entirely with Anime Studio.
http://youtu.be/MQAzmkyRq4c
Re: Barber Pole
Posted: Thu Dec 20, 2012 7:13 pm
by funksmaname
masks would be the way to go -
1) create a group with masking 'mask all'
2) create a layer set to 'add to mask' with the pole shape
3) ABOVE it, inside the group, create a 'stripes' layer and draw diagonal rectangles on it with an extra one belwo the pole (or a more nuanced, curved at the edges of the pole shape)
4) move the stripes up one position at frame whatever, and cycle it so it looks like they don't stop (use onion skinning to match them up. Set the keys to 'linear' interpolation so it rotates at a linear rate.
that's it - you should now have a rotating barbers pole.
If you want, above the stripes layer add another layer set to 'do not mask layer' and add some details like the ball at the top.
Here's one I just made in a couple of minutes (AS9)
http://www.mediafire.com/?8rm5wqoowxbd25w
Re: Barber Pole
Posted: Fri Dec 21, 2012 6:19 am
by msmart
Thank you Funksmaname, Incredibly easy! I cant believe I missed it.
Re: Barber Pole
Posted: Fri Dec 21, 2012 7:37 am
by msmart
Quick and easy Barber Pole after Funksmaname suggestion, Thanks again Funksmaname!
http://www.youtube.com/watch?v=X7FoAljr ... B44EEFAE60
Re: Barber Pole
Posted: Fri Dec 21, 2012 8:10 am
by sbtamu
Here is basically what funk describes but I just use lines and not shapes and I put 2 lines below the masked area.
Re: Barber Pole
Posted: Fri Dec 21, 2012 11:08 am
by msmart
umm ... one line is more percise then a retangle
Re: Barber Pole
Posted: Sun Dec 23, 2012 10:32 pm
by aaron
Thanks for the tutorial funksmaname! I was looking for the help and got it here
Re: Barber Pole
Posted: Sun Dec 30, 2012 6:53 pm
by funksmaname
nice idea with the line
Glad I could help
Re: Barber Pole
Posted: Mon Dec 31, 2012 6:34 pm
by sbtamu
For what it is worth, here is one I did the other day. If you want I will give you the .anme.
