Fluid cycles
Posted: Thu Dec 13, 2012 6:20 am
Hi,
I might raise an already long-discussed (and solved ?) issue in ASP, but how do you prevent cycle vectorial motions from making that little stop before the loop starts again ?
I have tried a couple tricks, which do not seem to work. I might have forgotten something though, as I havent practised vectorial animation in ASP for a while, mainly using it as a makeshift 2D stopmotion tool :
1°) Easing in the motion of my object on the previous keyframe, and then easing it out again doesn't seem to change anything.
2°) Slowing down the motion of my object when approaching the last keyframe of the cycle by bringing the vectorial points closer to each other does not seem to affect that little stop either.
Does anyone have any other solution to offer please ?
Here is a sample sequence to illustrate my problem...
