Image sequence ASP9 bug
Posted: Sat Sep 29, 2012 2:10 am
I have an image sequence of 300 png files (a 10 second rotating Earth) Transparent BG around the earth.
When automatically imported into ASP8-- everything is perfect-- the renders are clean and crisp.
When imported into ASP9-- the same resulting image sequence is horrible-- jagged edges on the pngs (I mean really bad)---plus the image size of each individual png is completely wrong.
However, when I import just a single image from the folder into ASP9 that the images are located in (not using the "image sequence import script" -- but simply "import" one image)-- the png is perfect, crisp edges and properly sized.
Anyone else with this problem?
regards
TODD
regards
TODD
