How to import moho animation on right frame in timeline
Posted: Sun Aug 21, 2005 2:35 pm
by ulrik
Hi!
I have one Moho project going, the name is "transman", and at frame 370 I would like to import another Moho project I made, it contents a lot of animation in a lot of different layers, and I want them to start at frame 370 in my "transman" project. Is it possible to do that in a smooth way so that I dont have to move every frame in all layers in the imported project so it will start at the right time?
I could not find anything about that in the Moho manual.
I would be greatful for all help I can get!
Ulrik
Posted: Sun Aug 21, 2005 2:52 pm
by F.M.
I don't think that importing Moho projects INTO another Moho project is possible at the moment. You can import Moho objects from other Moho projects, but the imported object would have the keyframes as they were set in the original project.
Posted: Sun Aug 21, 2005 2:53 pm
by rylleman
You can't directly import an animation starting at frame 370, but there is a quite easy workaround.
Open the project you're about to import, rescale keframes (entire ducument) so it starts at frame 370. Create a top group layer and put everything in this (easier import with just one group). Save this temporary projectfile somewhere.
In the transman project, import Moho object, select the new top node and now that animation starts at #370 (If you don't want to put everything in one top group you have to import every group one at a time).
Posted: Sun Aug 21, 2005 3:01 pm
by F.M.
Maybe it would be of use to you, if you were to render the project that you wish to import. Moho would import a movie file at any frame you want, A movie with an Alpha channel might be the solution. HTH
Posted: Sun Aug 21, 2005 3:07 pm
by ulrik
thanks rylleman and F.M foranswering so fast, I will try this rescale thing right away, it seems smooth and not to time consuming I think
Thanks again!
Posted: Sun Aug 21, 2005 3:08 pm
by mr. blaaa
jepp-
F.M. is right, that's the handiest and best solution i think.
(e.g. u can export with alpha channel 4 transparency, etc. and then import at the frame u wish to; PS: same with audio data)
Posted: Sun Aug 21, 2005 3:29 pm
by ulrik
I made as you said, rylleman, but I can't get it to work, when I try to rescale the whole document I get this warnig " do you really want to...etc, and I choose yes, nothing happens, the animations still starts at frame1...hmmm, I'll try some more.
I can import it as a movie file but I will have the opportunity to work some more on the animation to make it fit the new project so it would be nice to get this rescale thing to work
Posted: Sun Aug 21, 2005 3:42 pm
by ulrik
after rescaling the whole document with this setting: start frame=1 end frame=450 , new start frame=324 new end frame=774 the animation still starts at frame 1 but it's slower and streched and stops at frame 774, is taht a bug maybe? I'm running on a mac, osx 10.4.2
Posted: Sun Aug 21, 2005 3:55 pm
by mr. blaaa
hmmm... sorry about the "rescale"-thing (i can't help. let's see what rylleman will post) but i would prefer the method of importing a rendered movie into ur project.
can u give more detailled information about this project?
maybe ur problem can be solved otherwise.
Posted: Mon Aug 22, 2005 1:34 am
by rylleman
ulrik wrote:after rescaling the whole document with this setting: start frame=1 end frame=450 , new start frame=324 new end frame=774 the animation still starts at frame 1 but it's slower and streched and stops at frame 774, is taht a bug maybe? I'm running on a mac, osx 10.4.2
It's a bit buggy at times. 450-1=449, 324+449=773, try 773 as end frame, or if that doesn't work try 775, Moho doesn't seem to like moving and scaling a document just one frame.
Posted: Mon Aug 22, 2005 7:04 am
by ulrik
Ahhh...finally I found out what to do, I had to do a "Reset all layer channels" at frame1, then the "Rescale whole document" worked fine
Thanks for all support in this matter you're all very helpfull!
Posted: Mon Aug 22, 2005 7:32 am
by ulrik
ulrik wrote:Ahhh...finally I found out what to do, I had to do a "Reset all layer channels" at frame1, then the "Rescale whole document" worked fine
except for the events that were cycled, the cycling function disappered, the events where still there, but in this case there was'nt to much work to get them cycled again
Posted: Mon Aug 22, 2005 11:32 am
by mr. blaaa
hehe finally u did it
please share with us im coureous what you've created
Posted: Mon Aug 22, 2005 12:34 pm
by ulrik
mr. blaaa wrote:hehe finally u did it
It's only an experiment, I'm new in animation and Moho but I will put up my work as it progress soon
