Shadow Direction Animated
Posted: Fri Apr 27, 2012 3:02 pm
Here my problem...I'm using ASP8 and I'm trying to use the Shadow tab of the layer. So since I'm using it to a character which is moving in a room I'd like to change the shadow direction accordnlgi with the lamp position.
So I was not able to use the standard shadow tab since it is not possible to change the direction in different timeline....
I tried to use the masking approach (explained in the manual)....but I'm not able to use the mask in the swicth layers included in the character like the hand...(so you don't see the hands in tha shadow)....
Do you have some suggestions?
Thanks in advance
Thanks in advance
