adding bones after having finished the animation ?
Posted: Fri Aug 12, 2005 1:18 pm
by forw
.. this is possible, ain`t it? though i didn`t make it work yet..or I´m doing a s.th. wrong..
- creating a bonelayer - dragging the vectorlayer in it (bonelayer turns red for a second)
- activating the bonelayer and adding bones
this should do it IF it works, right ?
greetings,
forw :roll:
Posted: Sat Aug 13, 2005 2:21 am
by forw
ok, not possible .. :?
Posted: Sat Aug 13, 2005 2:38 am
by rylleman
Of course it works. just make sure you're at frame 0 and you should have no problem adding bones.
Posted: Mon Aug 15, 2005 5:50 pm
by myles
Hello forw.
I don't understand "after having finished the animation" ?
Bones are usually used for creating the animation in the first place.
I've created a small mini-tutorial on adding bones that shows adding bones.
Is this of any use ?
Regards, Myles.
Posted: Mon Aug 15, 2005 11:41 pm
by gochris
Often I will create an animation, render it as a quicktime, and then squash and stretch the quicktime .mov using bones. Gives me a kind of psychedelic effect. Just one more trick in the toolbox.
Gochris
Posted: Tue Aug 16, 2005 8:04 am
by MarkBorok
Cool idea, gochris.
In my experience, adding bones after an animation can be a headache and cause all sorts of problems. The new bones are going to interact with the bones you've already animated in unpredictable ways. Same goes for creating new vector shapes. I would create an ordinary vector drawing in frame 0 and then go to the first frame in which it becomes visible and the points would be all over the place for some reason.
Plan ahead. Don't do what I did.
Posted: Fri Aug 19, 2005 2:05 am
by forw
hi!
thanks for the movie!
i know this procedure but when i opened the thread i was doing something
wrong, so that i couldn`t add any bones ?!don`t know.
now that i know the program better I´ve done some short animations ..drawn my character..put in the bones..making him walk etc. ..when i wanted to add a feather on the hat of the guy after having done all that, strange things like MARKBOROK says happen.
maybe planing ahead is a good way to avoid strange things happening..
ciao,
forw
Posted: Sun Aug 21, 2005 4:17 pm
by mr. blaaa
whoot! myles!
nice tut u r offering!
(we shall talk to LM, to open up a special section for tutorials i think, cause i'm in the mood and new users have got questions :D)
