How Can I Make A Layer Object Transparent?
Posted: Tue Mar 06, 2012 7:41 am
by voxac50
I would like to be able to adjust the transparency of an object, meaning an outline with a solid fill color. I want to be able to draw lines within that object that relate to the selected layer and the one behind it. So far I am having to move the layer object out of the way, add my lines, and move the object back and re-align it. I tried adjusting opacity under compositing effects in the "General" layer tab, but the layer remains opaque at frame zero. I am used to adjusting layer transparency with a slider in Photoshop. Are there any equivalents in Anime Studio?
Posted: Tue Mar 06, 2012 8:02 am
You can switch off a layer's visibility temporarily, it's the eye icon on the layer tab.
Posted: Wed Mar 07, 2012 7:26 am
by voxac50
Thanks, I will try switching off the layer. But it would be helpful if I could retain the image in the layer, but make it transparent, as a ghost image, allowing me to see it and the image in the layer below it. Is this not possible?
Posted: Wed Mar 07, 2012 7:33 am
by VĂ­ctor Paredes
Layer transparency for images is showed only when the animation is rendered. You could try save your image as png with low opacity, that should work.
Also, you can try with the image masking tool. With this you can hide the fill of an image and see only the borders. It doesn't work with opacity, but could work for what you are trying to do.
Posted: Wed Mar 07, 2012 10:23 am
by neeters_guy
Another tip courtesy of selgin: If it's a vector layer...
1) go the layer palette,
2) click on the down triangle and
3) on the flyout menu, under Details,
4) check the Path checkbox.
It should now show as a ghost outline when you are in other layers.
Posted: Wed Mar 07, 2012 10:39 am
by jonbo
I believe that's only in the Pro version Neeters. If they have the Pro version, they could adjust the opacity in the layers properties menu but the Debut version won't allow you to do that. I just checked both versions.
Re: How Can I Make A Layer Object Transparent?
Posted: Fri May 12, 2017 7:38 pm
by jonobugs
I know this post is quite late, but in case someone else out there is looking I found the answer to this question.
On your layer's tab (right side by default) Click on the layer settings (the 3 dots ...). Select the Opacity setting and change 100% to whatever transparency setting you want. 25-30% is usually good enough to see the image but still be able to view the layer on top more clearly.
Posted: Tue Aug 22, 2023 3:35 am
by danielluz
Hi Guys,
Another option, if you want to have a solid stroke at 100% opacity, but have 50% opacity for the Fill, click on the top left Fill Colour Swatch - once the Colour Picker opens up, you will see there is an Alpha setting to the right of the box, just below the Red, Green and Blue number inputs.
Hope that helps!
