Improve Sea Waves
Posted: Thu Dec 01, 2011 12:27 pm
by Imago
I made this calm sea and I'm wondering how to improve the "water movement" drawing two different sea water layers and overlapping and moving them on 50% of opacity and putting them on a non-moving third water layer with 100%
How can I make it better without losing the "calm" aspect of it?
There's a video:
http://www.youtube.com/watch?v=TL2uVYH3NoE
Posted: Thu Dec 01, 2011 1:59 pm
Not much to be seen in the video because of compression ...
I see a right-to-left movement which seems quite fast, more like a river than a sea. I think you're much better off with one or two overlay layers of fine horizontal lines, which you move only a bit up and down.
Posted: Thu Dec 01, 2011 7:16 pm
by Imago
I'll try to make it more visible, but there are two semi-transparent layers wich goes from right to left the first and viceversa the other one, the third one doesn't move.
I'll also try do give them an vertival movement.
Thank for the tips!
Posted: Thu Dec 01, 2011 8:14 pm
by Genete
I wouldn't worry too much of the sea movement unless you were to zoom in to it because it were the place where the action happens. If the action is in the ground I would just make a static sea.
Posted: Thu Dec 01, 2011 9:29 pm
by J. Baker
It looks like it's flowing like a stream. A sea has more of a random lighting effect. Like dimming the lighting in and out in multiple areas with constrained movement.
But like Genete said, a static sea would be fine as long as it's not the focus.
Posted: Thu Dec 01, 2011 10:04 pm
by sbtamu
Just about every one on the forum helped design this water. If you want to use it I'll send it to you.
http://www.youtube.com/watch?v=4VFp84WwKEY
Posted: Fri Dec 02, 2011 10:51 am
by Imago
Sbtamu, that water effect is very good!
How do you made it? Maybe I can modify it to obtain the desired effect!
*EDIT*
In the meanwhile, I made a new clip:
http://www.youtube.com/watch?v=sxq7rEv-Okw
Use high definition!
Posted: Fri Dec 02, 2011 7:07 pm
by ruscular3d
Can you post the project file on how you made that?
That was very good effect.
Posted: Fri Dec 02, 2011 8:26 pm
by sbtamu
better yet, I will record a tutorial later today.
Posted: Sat Dec 03, 2011 2:52 am
by sbtamu
It seems I can not do a video tutorial on this. My screen capture program crashes every time I render the water in GIMP. So I'll just upload the files and you can look at them. I will also post a link to a Tutorial in youtube that shows how to make the water.
The AS 7.2 Pro file.
http://www.sendspace.com/file/b9s3f2
The water(you will have to convert this to a file AS can read)
http://www.youtube.com/watch?v=nMUbSM_5zpM
