Exported AVI goes really really unsmooth
Posted: Tue Nov 29, 2011 9:54 am
by tonico
Hi,
this is my first post. I've been lurking for a while but can't find the same issue posted.
I got ASP8 last week (couln't not get it after seeing the discount), and I have played with it just a little so far.
The software goes well except when exporting, I have come a bit frustrated as the exported video is not good.
The resulting video goes slow and bumpy, like step by step, with pauses, not smooth at all. When I check the "Render at half dimension" box, it is a bit better (not perfect), but then it loses sharpness (looks like blurry) and vividness.
My laptop is not a great machine, but it seems to have all the necessary specs. So what can be the problem?
Thank you very much in advance.
Posted: Tue Nov 29, 2011 10:07 am
by GCharb
Looks like You exported to an uncompressed avi, that is, a video that is not compressed at all, which is usaly very big and only very powerful computers can play those back.
When exporting, choose a codec under compressor, like xvid (if the codec is installed on your system) or any other codecs that are available.
Uncompressed avi is good if You want to import into a video montage software or for more processing, it is no good for playback.
Also, I strongly suggest You use Quicktime instead, as it has more and better compression codecs.
You can find Quicktime here if You do not have it already!
http://www.apple.com/quicktime/
Posted: Tue Nov 29, 2011 10:21 am
by J. Baker
If you are using a Windows pc, then download and install the Lagarith codec, http://lags.leetcode.net/codec.html
Then just select this codec when you export to avi from Anime Studio. It's the best lossless codec ever, for pc users anyway.
Posted: Tue Nov 29, 2011 10:50 am
by funksmaname
Thanks for the link J, I tend to use quicktime export for everything - havn't exported AVI in a loooooong time.
Posted: Tue Nov 29, 2011 11:01 am
by GCharb
Funk, same here, only use avi to export uncompressed.
Thanks for he link Mister Baker!
Posted: Tue Nov 29, 2011 11:29 am
by J. Baker
No problem. Quicktime is great too and I use it on Mac but I still prefer Lagarith on PC. It's lossless compression looks just as good as a non-compressed avi and plays back just as quick as compressed formats. It's great for editing and video overlays (alpha channel) too.
Thank you
Posted: Tue Nov 29, 2011 12:53 pm
by tonico
Thank you very much guys,
I have downloaded the lagarith and it works perfectly.
As for exporting in quicktime, it seems that I have to restart the system for the newly installed xvid codec to appear in the exporting options...
buy yeah, the problem was I wasnt using compression. ^^'
thank you!
Posted: Tue Nov 29, 2011 1:50 pm
by GCharb
You are quite welcome, stop by from time to time to say hi! :)
Posted: Fri Apr 13, 2012 8:36 pm
by KartoonManagement
Always wanted to know how to fix this problem. I thank you so much for that codec! You guys are awesome!
