Help needed: Mask disappear in preview/workspace
Animark
Post by Animark »
Hello,
I am on win7/64 using ASP 8.01. Now I have a problem I never had in ASP 6 on the same machine:
I am using some simple masks. Everytime I scratch over the timeline the masks disappear. Everytime I press F5 to get an animated preview the masks are not rendered. Where the mask should be only white appears.
When I am doing a full rendering using export, everthing looks fine.
Does anybody have a solution for me - or maybe a hint where I can have a look at?
Thanks from Animark.
BTW: Is there a way to use my ASP8 Files in ASP6?
Check if the masks are set to "visible" all the time, both in the layer palette and the layer tab. Also check for their transfer mode, I once made a mistake like that and searched for days ...
Animark
Post by Animark »
Hi Slowtiger,
Thanks but sorry, I don't find anything you're talking about ... maybe caused in my german version of ASP. I checked all settings of the layers inside the masking group and the group itself but didn't find anything helpful.
I don't think it is caused by some layer settings - the same document opend in ASP 6 don't have this problem.
The problem also occurs everytime I click a mousebutton.
