Noisy outlines are fantastic
Posted: Mon Oct 03, 2011 9:05 am
by Víctor Paredes
Hi, I have no time to explain this "technique" right now, but I want to share some advances.
I was working in a project with psd files and bones, everything normal. But in a scene a character should move from one pose to another and there was no way to make it only with psd. So I decided to use vectors, emulating the sketchy style.
I had problems with the hatched parts and this involved a lot of lines, making it a nightmare to animate them. Then I realized the noisy outlines could help.
The idea is simple, instead of drawing and animating 18 lines, I drew 3 and multiply them via noisy outlines (on vector layer proprieties). It worked fantastically and made the animation very easy, moving a couple lines you can move an entire hatched part.
The final result was very close to the original psd picture.
Posted: Mon Oct 03, 2011 9:29 am
by jahnocli
What a cool idea...
Posted: Mon Oct 03, 2011 9:31 am
by GCharb
Nifty, thanks for sharing!
Posted: Mon Oct 03, 2011 9:33 am
by Genete
Wizard! you're a wizard!
Posted: Mon Oct 03, 2011 11:54 am
by neeters_guy
Agree, that's fantastic.
Posted: Mon Oct 03, 2011 12:13 pm
My first reaction: WOW!
This is just great. *bows*
Posted: Mon Oct 03, 2011 12:15 pm
by SvenFoster
woaaahhh. some of it I can see the use of the noisy lines but others I'm thinking how the *** did he do that?
i guess thats what the developers had in mind when they did the noisy line option
awsome as ever
Posted: Mon Oct 03, 2011 12:52 pm
by ulrik
Fantastic Selgin, you're a magician!
Posted: Mon Oct 03, 2011 1:45 pm
by Víctor Paredes
Thanks for the nice comments, guys, I didn't expected this kind of reaction.
I just uploaded the original image to the first post, so you can compare them with the final result. I know there are many differences, but the overall look is not bad.
Blend morph helped a lot to make the movement easier. Actually, thanks to the rig, the actual animation took no more than one hour.
Sadly I can't share the anme file yet, so if anyone have any question about it, just ask.
I'm very excited, this could open a big door for a kind of animation which seemed to be very difficult to do in AS.
Posted: Sun Oct 09, 2011 5:47 pm
by NeedyN00b
What values did you use for your noise settings?
Posted: Tue Oct 11, 2011 5:15 am
by Víctor Paredes
NeedyN00b wrote:What values did you use for your noise settings?
Around this:
Posted: Thu Jan 12, 2012 7:45 am
by DocZagreus
Noisy uotlines are amazing, indeed, but is there a way to modify an animated noise speed?
Posted: Thu Jan 19, 2012 7:37 pm
by chucky
That's a feature people have been begging for, unfortunately no, but you could reduce the overall frame rate I guess, that 's what I end up doing more often than not. Animating vectors on 2's and more can take the 'video' look out of the work anyway, one's can look a little
too slick sometimes.
BTW Selgin, bloody great
Posted: Sun Mar 25, 2012 6:45 am
by SpaceBoy64
That's very nice work! Thanks for all the hints and tips.
Good idea using noisy outlines as hatch shading. I see how you didn't click the animated noise setting. Your keyframe animation makes it move nicely.
I used noisy outlines on a project of mine in 2010 that was supposed to look hand drawn frame by frame. I used just enough animated noise to make each frame slightly different. I had to experiment with it to get it to look just right. I used a small offset, and medium scale, with 1 line.
The editor took it upon himself to add fields in After Effects which I think was unnecessary.
Re: Noisy outlines are fantastic
Posted: Fri Feb 01, 2013 10:17 am
by delongeorama
Awesome... Please make a tutorial for this!
