Bones don't move points
When I click on a bone the correct points turn red but they don't move. My character has both layer and point binding bones so I can't figure out where I screwed up. I deleted a layer bone and replaced it with four point binding bones because now I want to control a thumb that presses a button.
Cheers, Larry
- Víctor Paredes
You can't bind a layer and have binded points in the same layer. If the vector layer is binded to a bone, all its points will move with that unique bone.
Try this, select the vector layer with the problem, go to
Bone>Release layer
then go to
Bone>Flexi-Bind layer
That should solve the problem.
PD: Many times is better to bind all the points to a bone instead of bind the entire layer, this way you can easily solve possible future problems.
Bone>Release layer
then go to
