fade script
Posted: Sun Sep 18, 2011 1:42 pm
by babyshoe
I tried it but my character simply disappears!
are the scripts to be used as is? the manual says you don't need them if you aren't into programming. But I want to fade in/out!
also: how to fade in/out an entire scene?
please help!
thanks
Posted: Sun Sep 18, 2011 2:40 pm
by funksmaname
you have two options, either key the transparency of a layer out, or if you want to fade a whole scene its probably easier to put a solid layer on top of everything and fade it in instead of out.
Read the manual about keying transparency of a layer.
Also, render to see the actual fade - I dont think you see the fade until render so it will look like a on/off at the end of the transition but it is actually fading.
