Characters with Heavy Outline: How?
Posted: Wed Sep 01, 2004 10:47 am
by GullyFoyle
How would I get a character to output with a heavier outline around the outside edge?
Posted: Wed Sep 01, 2004 11:29 am
by Lost Marble
If you have the 4.6.3 version of Moho, take a look at Tutorial 20 (actually, just the last part of that tutorial). The trick is to use a layer shadow, with specific settings.
Posted: Thu Sep 02, 2004 10:33 am
by GullyFoyle
Wow that was ridiculously simple. I should kick myself! Thank for the quick response! :)
Posted: Sat Sep 04, 2004 10:49 am
by Armaani
One thing to note about this technique: scale compensation doesn't apply to shadows, which means if your animation involves scaling the outlined character, the outline will seem to change in thickness. The effect is similar to what is shown on Moho's Feature Page (look at the scale compensation sample under "drawing features"). You can manually adjust the shadow's expansion parameter to emulate scale compensation, but there's limits on how high expansion can go.
If, on the other hand, your animation doesn't scale the character, then the layer shadow trick will be perfect.
