Page 1 of 2
PNG transparency
Posted: Mon Jun 27, 2005 9:40 pm
by bupaje
I'd like to see transparency enabled for a PNG skin on a 3D object if that is possible? I tried using a skin with transparency but doesn't seem to show transparent areas on 3D objects.
Also is it possible to add -not sure exactly what it is called- but transparency that uses a mask -so you have gradiations of transparency -for example areas that are gray are only partially transparent? Unless I missed something this doesn't seem possible with imported png.
It would be nice to have this for brushes as well; I'm thinking along what Toontoonz was saying about the brushes limitations; if you could draw a brush that had variable areas of transparency maybe where the brush overlapped along the line.
I did a quick mockup in PSP to demo what I mean. The top line is a normal brush. Then I made one with a mask to make the brush fade out from the center. Now the lines look slightly different depending on the distance of the brush spacing and the resultant overlap -or lack of overlap.
Posted: Tue Jun 28, 2005 9:56 am
by nobudget
I can't say if it works for 3D but unless I'm mistaken you also refer to 2D layers right? In that case transparent .png files work. You need a .png image with an alpha channel. Here's an example:
http://www.nobudgetvideo.com/moho/trans ... xample.jpg
A .png layer rendered over a Moho background with some black and white shapes. The shadow and dissolving bar is transparency information contained within the .png file, that's the grayscale area you refer to.
http://www.nobudgetvideo.com/moho/transparent_bg.jpg
The original background layer.
http://www.nobudgetvideo.com/moho/moneytv.png
The .png with transparency.
Is that what you meant? I haven't tried it as a brush but I suspect that would be the same.
Good luck,
Reindert.
Posted: Tue Jun 28, 2005 10:09 am
by bupaje
Hmmm... I must have missed something. When I have tried in PSP to export PNG I can export stuff that is either 100% opaque or 100% transparent but I can't get the say 50% transparent and other gradiations. Maybe I am missing one of the settings. If anyone is doing this with PSP and able to export partial transparency can you post a screenshot of the PNG export dialogue with your settings?
If this is already possible and I am wrong then LM may want to move this to the "How Do I..." forum.
Still interested in 3D if LM thinks it worthwhile. I was trying to create 3D sky sphere and then a 3D sphere within this with clouds and ground fog to slowly rotate around the camera as a continous moving background.
Thanks a lot.
Posted: Tue Jun 28, 2005 8:35 pm
by 7feet
I just tried it (this is my quicky 10 second check), but it would seen that the default (in the PSP7 I'm using) is only background transparency. I tried the Export>Optimized PNG and set it to Alpha Transparency and it worked just fine. Probably other settings in there, but like I said, it's the 10 Second Check.
Posted: Tue Jun 28, 2005 11:57 pm
by bupaje
Thanks. There some to be a tiny bug in PSP9 with the options as I didn't get it but after I switched to an other option and switched back it showed in the window. It still didn't work until I did the following -I'll note it here as I'll probably forget otherwise. Might be some extra steps in here ...
-I created a 128x128 image with transparent back
-I drew my brush
-New Mask Layer: from image, source luminance, invert data
-Selections: From Mask
-Export: PNG Optimizer: Use Wizard: 16.7 Million Colors: Existing Transparency
If you use the "use existing transparency" option on the PNG Optimizer advanced interface -instead of using the simpler 'wizard' the generated file does not work as intended in Moho -no partial transparency- but the wizard doing those steps I quickly mentioned above does; has to be a bug. Will see if I can explain it coherently on the Corel forums tomorrow but I doubt it. :)
The good news for me is that I think I'll be able to come up with some nicer brushes - if I'm right I'll be posting one or two over the next few days.
Thanbks for pushing me in the right direction.
Posted: Mon Nov 14, 2005 5:31 am
by rylleman
Hey Bupaje!
Did you manage to get transparent brushes?
I would really need it now, I have done a lot of tests but I cant get it to work.
I create semi transparent brushes but when I use them the line turns out with no transparency at all. If I import the brushes as images they got their transparency.
Strange thing is that in the versions where I created the transparency with a mask you cant see any transparency at all in the brushes settings dialog (I made a big transparent hole in the brush, so it should be pretty obvious).
I'm using photoshop CS2 to create the brushes in.
Posted: Mon Nov 14, 2005 7:03 am
by jahnocli
16.7 Million Colors
Unless I'm mistaken, 16.7million colours is 24-bit colour -- you need 32-bit export to get the partial transparencies you mention.
J
Posted: Mon Nov 14, 2005 10:34 am
by nobudget
Correct about 24Bit - 16.7M colors, but the other 8 bits are 256 values of grey to create the alpha. So if the export states a 16M color export with alpha it basically gets exported as 32 bit. But programs tend to use their own definitions which makes it quite confusing. Quicktime calls it Millions+ and + means alpha and they don't seem to care about the exact number of millions either... Adobe has a PNG256 and PNG24 and 24 is with alpha for instance.
I could be wrong but I think what I wrote above is correct. That said, it's all so illogical I'm losing track reading my own post :?
Reindert.
Posted: Tue Nov 15, 2005 2:53 am
by rylleman
But can you have (semi) transparent brushes in Moho or has this discussion just gone to a discussion of png transparency in general?
Posted: Tue Nov 15, 2005 4:10 am
by nobudget
My input was general...
Reindert.
Posted: Tue Nov 15, 2005 4:37 pm
by bupaje
rylleman wrote:Hey Bupaje!
Did you manage to get transparent brushes...
I don't remember. My memory has some holes in it and is wonky at the best of times. I haven't been able to play with Moho because of the homework load but if I find time -and that's a big if- I'll try to go through all the brushes to see if I managed to create any that worked.
Sorry for the unhelpful answer, if I do come up with anything I'll post it. :oops:
Posted: Tue Nov 15, 2005 11:02 pm
by bupaje
@rylleman - I took a quick look and these look like likely culprits - the goal was to see if they worked rather than pretty brushes so ... hope they might be of some use ...
http://www.stormvisions.com/moho/test_brushes_1.zip
Posted: Wed Nov 16, 2005 7:19 pm
by bupaje
Well rylleman asked about the PNG transparency and at least 1 or two of those brushes I posted seem to have it right.
Here is an image. The top grass and soil was with a brush with transparency, the bottom grass and soil with a standard brush
Here is a test of another. The middle is a standard brush and the outer two with brushes containing alpha
Hope that helps someone.
EDIT: Or maybe I don't know what I'm talking about. I took a quick look at these in an image viewer and I don't see that they have transparency info?
Posted: Thu Nov 17, 2005 2:56 am
by nobudget
I think you know what you are talking about, the 4 images in the zip file have transparency information, I just checked in a paint program and the examples you posted look very good!
Reindert.
Posted: Thu Nov 17, 2005 1:36 pm
by bupaje
nobudget wrote:I think you know what you are talking about, ...
Whew! Glad that worked must have been whatever I used to look at the image info last night. :)
