PSD linking
Posted: Thu Jun 23, 2011 12:36 am
by funksmaname
Once a live link has been established with a PSD file, can layers be added to the PSD or only existing layers editted?
Posted: Thu Jun 23, 2011 6:05 pm
by Mikdog
Ok, hopefully others view this:
The way the PSD link script works is - AS references layers form their position in the Photoshop stack, from their layer position from the base layer. So, if you add layers, be sure to add layers right at the top of the stack otherwise if you add layers in the middle of the stack and save the PSD file, the wrong layer may get referenced in AS.
However, the new layers will not be added to the AS file (it would be great of they were). Instead, you'd need to re-import the PSD file, and kind of manually cobble the layers into your AS file. Can get a little confusing and nuts.
So its got NOTHING to do with the layer names - its about their position in the layer stack. Hope this helps.
Posted: Thu Jun 23, 2011 6:58 pm
by VĂ­ctor Paredes
Anyway, just to take in count, if you imported the psd as consolidated, the new layers will be added without problems.
Posted: Thu Jun 23, 2011 9:10 pm
by funksmaname
thanks guys,
@selgin, I was thinking more of a scenario where you importing PSD switch layers and needed more inbetweens or a new pose after having already dome some animation in AS rather than importing a 'flat'
