Unable to access Actions Window
Ahroo
Post by Ahroo »
When I try to open the Actions Window (either by going to "Window" in the menu bar and clicking on "Actions" or by hitting CTRL+K) the Actions Window does not appear. The checkmark in front of the word "Actions" in the Windows drop-down menu is there, but no actual window appears. This is AS 8 Pro. I am wondering if it is hidden somewhere, but I cannot find it. Any suggestions? Thanks!
Added - I tried undocking all the other windows (tools, timeline, etc) in case it was hiding behind one of them, but the Actions Window was not anywhere to be seen.
Ahroo
Post by Ahroo »
I finally figured it out and I'm posting this just in case anyone else has the same problem.
I had to change the display options (under Personalization - Win 7) to a smaller setting to be able to see the window that was off to the side. Then I could move it to a location that is visible when I change the display option back to the larger size that I use. Fortunately it remembers the new location so I should only need to do this one time.
