Help animation in black and white
Posted: Sat Apr 09, 2011 12:01 am
by shift
I don't know why, but my animation is rendering black and white even though it's in color in design view. How do I remove this?
Posted: Sat Apr 09, 2011 12:11 am
by shift
This is how I want it to come out.
This is how it is coming out
What do I do?
Posted: Sat Apr 09, 2011 7:02 am
by PARKER
May be you havent realized that your shapes has a style applied? make sure to set i to none.
Posted: Sat Apr 09, 2011 8:39 am
All your shapes have a gradient applied to it. It doesn't show in edit mode, but you'll easily see it in the styles palette. Select all shapes (with the Q tool), then set the effect to "none".
(But it's interesting, in a weird way. Maybe somebody could use this ...)
Posted: Sat Apr 09, 2011 5:37 pm
by shift
It is interesting in a weird way. I was thinking of using the effect to suggest someone reflecting on the past. I just need to figure out how I did it in the first place lol. Thanks for the help guys. I haven't tried your suggestions yet, but they make sense so I'm sure they'll work. I have to go on the road now. I spent most of Today in a meeting, choreographing a fight scene for a music video and drawing a comic strip I added to my blog. No animation practice as yet. :(
Posted: Fri Apr 15, 2011 10:59 am
by shift
I tried what you suggested. Still not working.
Image[/img]
Posted: Fri Apr 15, 2011 12:06 pm
by VĂ­ctor Paredes
I'm pretty sure you are doing it wrong.
Use the select shape tool, select a shape, then go to style window, check that both combos in effect be "plain".
Repeat the same process with each shapes.
PD: another option is that a style is being applied to each shape. Go to style window, Style combo. If there is an undesired style there, select it and then go to the style combo, delete.
Posted: Fri Apr 15, 2011 4:01 pm
by shift
That's what I did and results are still the same. I'm starting over the animation.
Posted: Fri Apr 15, 2011 4:04 pm
by shift
OK wait...I'm making progress. Not all of it is gone but most of it is. Going over the objects again to see what still has an effect on it.
Posted: Fri Apr 15, 2011 4:07 pm
by shift
Oh crap now I see what's happening. Each blade of grass is an individual object. I have to go click each one and undo the effect. Yeah, I'm starting over.
Posted: Sat Apr 16, 2011 3:29 am
by jahnocli
One way round making these laborious changes in the future is to have a particle effect represent grass. Search the forum -- a number of people have done it (and there may even be a tutorial on this...)
Posted: Sat Apr 16, 2011 10:01 am
by Mikdog
My advice - don't use styles. You'll probably end up running into similar problems like this down the line. Enough to make a person despair.
