what about import poser escenes inside ASP7?
cocoOS
Post by cocoOS »
Hi...I'm know it's a recurrent discussion but I saw this video
http://www.youtube.com/watch?v=62RDRW5y ... 3BC23B095B
and for me it's pretty amazing...I tried do it but I can't...I try import a "poser scene" (no a obj) inside AS but I get a error...it say something about error "initializing or serializin poser please check the correct poser folder inside the AS configuration"...and then I check inside configuration and everything is correct...the poser folder is rigth but I can't import poser escenes still...
when I import a object is very hard animate...It don't look like the video...check the video and you can see than inside his layer tool he has the poser tool active...I never have it activate :(..please if anyone can help me... :D
jonbo
Post by jonbo »
which version of poser are you using? to use the poser interface in as7 you need to use poser 7 or higher.
cocoOS
poser 8
Post by cocoOS »
Hi...I'm using poser 8...but the import poser escene seem don't work with me...this show a error message (about a bad ubication poser folder..I check this inside AS configuration and the folder is in the correct place ) or simply don't do anything when I select the poser escene :?
I can import OBJ but I wish import a animation...import a OBJ and animate inside AS look difficult
jonbo wrote:which version of poser are you using? to use the poser interface in as7 you need to use poser 7 or higher.
crsP
Post by crsP »
I don't know this for sure, but I don't think you animate in ASP the Poser models as such. From what I gather you animate it in Poser the morph targets, and then you have those available in ASP to lay on the timeline. Of course you can animate camera in ASP as per usual. Maybe someone with experience of using Poser and ASP can clarify these things.
jonbo
Post by jonbo »
I have had difficulties myself at first with poser, but with some experimentation I got it to work. First of all, the error you're getting.. I think, is the path to the poser program is not correct. In anime studio, go to the edit menu, preferences, poser location. This needs to be set to the location of the poser program itself and not the poser object file location. Make a scene in poser and save it. In anime studio, choose file, import, poser scene, and choose the scene you just saved. Depending upon the complexities of the scene and the power of your computer, it can take a few minutes to load in the scene.when the scene is imported, the poser tool should now be selectable. Go to the window menu at the top and select the poser parameter submenu. You can use the sliders on the submenu to animate with. There are some other tricks to keep in mind. Let's see if you can do this first and we will get into those later.
jonbo
Post by jonbo »
crsP,you can animate poser objects in AS7pro like they show in the video.Also when you import a poser scene, if you had any keyframing done in poser , they will be imported as well and will show up in AS on the timeline.
jonbo
Post by jonbo »
here's a quick example of how I got it to work.Sorry , the audio is out of sync ,this is the first time I used this screen capture program and the settings are not right. :oops:
http://www.youtube.com/watch?v=bPbpayqflk4
cocoOS
Post by cocoOS »
hi jombo..thanks for the fast answer and the amazing video...I can solve the error (inside configuration the path was "c:..program files" but my poser is inside "c:...archivo de programas" :oops: :oops: )...now I can work with poser and AS pro...many many thankss!!
jonbo wrote:I have had difficulties myself at first with poser, but with some experimentation I got it to work. First of all, the error you're getting.. I think, is the path to the poser program is not correct. In anime studio, go to the edit menu, preferences, poser location. This needs to be set to the location of the poser program itself and not the poser object file location. Make a scene in poser and save it. In anime studio, choose file, import, poser scene, and choose the scene you just saved. Depending upon the complexities of the scene and the power of your computer, it can take a few minutes to load in the scene.when the scene is imported, the poser tool should now be selectable. Go to the window menu at the top and select the poser parameter submenu. You can use the sliders on the submenu to animate with. There are some other tricks to keep in mind. Let's see if you can do this first and we will get into those later.
cocoOS
Post by cocoOS »
jonbo
Post by jonbo »
glad to help. I don't know everything about this, but will answer anything I can as I have alot of time on my hands now. post some work you do with it, I'd love to see somebody do more work with this under-used feature.
