Mouth Shapes?
Posted: Tue Mar 08, 2011 6:06 am
by Leejohn
Hi, I was wondering if anybody had a clear diagram or manual describing the mouth shapes. I was also wondering how many different mouth shapes were necessary for the full range of speech. Thanks.
Posted: Tue Mar 08, 2011 8:59 am
Two, or 26, or any other number, depending on your style.
Google "mouth shapes".
Posted: Tue Mar 08, 2011 2:29 pm
by benecosse
Posted: Tue Mar 08, 2011 7:18 pm
by Leejohn
Thank's very much for your help.
Posted: Wed Mar 09, 2011 12:25 am
by madrobot
"Thanks to you" is abbreviated to "Thanks"
Your post is an abbreviation where the apostrophe replaces parts of a word;
"Thank Jeebers" -> "Thank's", for example
(No need to thank me)
Posted: Wed Mar 09, 2011 6:04 am
by Leejohn
Don't worry, I won't.
Posted: Tue Jul 26, 2011 6:53 pm
by that1guy
On the subject of Phonemes, I just created my first mouth set using the ten phonemes that Papagayo recognizes (the Preston Blair set). The guide says that the layer labeled ETC will be used for the letter T and for pauses. During my first test I see that the L phoneme is being used for the T sound and it looks silly. Is there any way to adjust this or even to use extended phonemes without having to manually switch at individual frames?
Posted: Tue Jul 26, 2011 8:12 pm
by jonbo
Hey John, do you have the etc phoneme named with upper case? Both the etc and rest should be lower case because that's how papagayo's dat file shows them and it won't switch right in AS leaving the last phoneme active instead of switching.
Posted: Tue Jul 26, 2011 9:15 pm
by that1guy
Tahnk you, jonbo, tha was the problem. I was skipping over here to tell the world about your advice.
You saved me hours. thank you.
John
