One command line render and one keyframe question
Posted: Tue Feb 08, 2011 11:19 am
by resle2
Hello,
I am using Anime Studio to create various frame sequences for an animated character to be used elsewhere.
Thus, I have several separate actions.
Now, I'd need to render such actions from command line in some way, but for now I'm able only to render the mainline. Is there some way to specify the action of which I want to render some frames?
Also: I'd like to know if there's some way to put a keyframe for all bones of a certain bone layer at the same time, on a given frame. This, because if I put all the actions in sequence on the mainline, by referencing them one after another - I'd need to put some... "stop" frame between them, to prevent one from influencing the movement of the following.
Thanks in advance for your assistance!
andrea
Re: One command line render and one keyframe question
Posted: Tue Feb 08, 2011 12:25 pm
by neeters_guy
resle2 wrote:Hello,
There are several scripts that do this, notably, MKelley Key Skeleton script. See this thread:
How to key all bones at one touch?
Posted: Tue Feb 08, 2011 12:55 pm
The batch render works like this: drag several .anme files on it and start the render.
Posted: Tue Feb 08, 2011 4:25 pm
by ponysmasher
Unfortunately you can't send parameters like that via the command line renderer. Sure would be nice though if you could specify to only render certain layers or certain actions.
Posted: Tue Feb 08, 2011 8:24 pm
by Rudiger
I may have a Python script laying around that may give you a hand to do what you want. It basically acts as a wrapper for the Anime Studio command line renderer and offers some useful extra options. The one you would be interested in is the startup script option which you could use by writing a simple startup script that places the action that you want on the main timeline. However, it works using embedded scripts, so if you are using version 7 with a multi-core processor you will most likely have problems.
Posted: Tue Feb 08, 2011 11:42 pm
by resle2
Thanks for the Key Skeleton script, neeters_guy! It works almost flawlessly. There's just one thing left out from it as far as I tested it for now: layer translation, which doesn't get keyed (at least in AS 7)
Rudiger wrote:I may have a Python script laying around that may give you a hand to do what you want. It basically acts as a wrapper for the Anime Studio command line renderer and offers some useful extra options. The one you would be interested in is the startup script option which you could use by writing a simple startup script that places the action that you want on the main timeline. However, it works using embedded scripts, so if you are using version 7 with a multi-core processor you will most likely have problems.
Aaawww... yes, I am using a multicore setup... many, many cores infact... what problems could I have?
Posted: Wed Feb 09, 2011 12:21 am
by Rudiger
There appears to be a bug in the multi-core rendering in AS7 that causes it to crash when you have embedded scripts. I reported the issue to Smith-Micro slightly before 7.1 was released, but there's no news on a fix at this stage.
Posted: Wed Feb 09, 2011 12:39 am
by resle2
ponysmasher wrote:Unfortunately you can't send parameters like that via the command line renderer. Sure would be nice though if you could specify to only render certain layers or certain actions.
And, from a coder's point of view - I am reasonably sure that both things would be extremely easy to implement.
Selective layer rendering would be as easy as adding a -layers "name1,name2,name3" and/or -hide "name1,name2,name3" switch which the program would parse to set visibility on given layers.
Rendering actions: -timeline "name", or even timeline "name1,name2,name3".
In general, if the GUI can do something without in-between interaction from the user (answer dialogs, click somewhere etc.) - then porting that to the command line is as easy as writing ten lines of additional code.
Version 8 perhaps?
Posted: Wed Feb 09, 2011 12:48 am
by Rudiger
resle2 wrote:ponysmasher wrote:Unfortunately you can't send parameters like that via the command line renderer. Sure would be nice though if you could specify to only render certain layers or certain actions.
Version 8 perhaps?
Selecting an action to render instead of the main timeline is probably OK, but I wouldn't want the command-line interface to get too many options. I think specifying a startup script that specifies which layers you want to make visible is a cleaner way to do it. I guess the best of both worlds would be if the scripting interface had access to the command-line that was used to invoke AS. Then you could pass command-line arguments to your start-up script and have all the crazy options you might think of.
Posted: Fri Feb 25, 2011 10:28 am
by Rudiger
Wow, putting together a polished product sure is a whole lot more work than throwing together a quick script that does the job. My Python wrapper script for Anime Studio Pro's command-line renderer is now up on ContentParadise
http://www.contentparadise.com/productDetails.aspx?id=17468. Sorry about charging for it, but I plan on continuing to provide startup scripts for it, free of charge.
Anyway, once such script is
selective_render.lua. If you're still interested in rendering only selected layers and actions, you can use this script together with ASPWrap it to do just that, right now!
Here are the options it supports. As as you will see, they are very similar to what you requested for a future version of Anime Studio
-- -show_layers "layer_name1,layer_name2" Specify list of top-level layers to show.
-- -show_only_layers "layer_name1,layer_name2" Specify list of top-level layers to show and
-- make all other top-level layers invisible.
-- -hide_layers "layer_name1,layer_name2" Specify list of top-level layers to hide.
-- -hide_only_layers "layer_name1,layer_name2" Specify list of top-level layers to hide and
-- make all other top-level layers visible.
-- -action "action_name" Render specified action instead of main timeline.
-- -auto_frame_range yes*/no Automatically adjust frame range to match selected action.
Example:
python "c:\Program Files (x86)\Anime Studio Pro 7\ASPWrap.pyo" -r selective_render_test.anme -s selective_render.lua -show_only_layers "Layer 1" -action "Scene 1"
Posted: Sun Feb 27, 2011 3:08 am
by rylleman
Rudiger wrote:...My Python wrapper script for Anime Studio Pro's command-line renderer is now up on ContentParadise ...
Wow!
This is going to be a tremendous help as I'm almost always uses renderpasses. Up until now I've had to manually select layers and save different renderpass files.
Thank you.
