Scale artwork while retaining line width?
Posted: Sun Feb 06, 2011 12:26 am
by Manu
Is it possible to scale some artwork with the scale points tool and scale the line widths up at the same time?
Actually, I have already tried, so I know it's not possible. But is there a script that does this?
Posted: Sun Feb 06, 2011 4:27 am
by PARKER
To increase the width of the line along with the size of your shape you should scale the layer not the shape, thats the only solution i can think about now.
Posted: Sun Feb 06, 2011 12:16 pm
by Manu
Right, better roll up my sleeves and learn a bit of Lua. That's too big a gap in the feature set I'd say.
Posted: Sun Feb 06, 2011 3:04 pm
by Manu
Well, I've got it working. Thanks to the wonders of copy and paste, I was able to make the first version in less than half an hour :D
All I did was make a replacement version of the lm_scale_points.lua script that scales the line together with the points. Here's the script for those of you who want to try it. All you have to do is replace the contents of the lm_scale_points.lua script with this. Made for 5.6, so no idea how it works for higher versions.
Note that I didn't add a button to switch the line scaling on and off. Also, I haven't commented the code in any way, which I know is big no-no, so only use this if you're curious and remember to back up the original lm_scale_points.lua first.
ScriptName = "LM_ScalePoints"
LM_ScalePoints = {}
LM_ScalePoints.BASE_STR = 2280
function LM_ScalePoints:Name()
	return "Scale Points"
end
function LM_ScalePoints:Version()
	return "5.0"
end
function LM_ScalePoints:Description()
	return MOHO.Localize(self.BASE_STR, "Scale selected points (hold <alt> to preserve volume)")
end
function LM_ScalePoints:Creator()
	return "Lost Marble"
end
function LM_ScalePoints:UILabel()
	return(MOHO.Localize(self.BASE_STR + 1, "Scale Points"))
end
-- Recurring values
LM_ScalePoints.scalingDir = -1
LM_ScalePoints.minVec = LM.Vector2:new_local()
LM_ScalePoints.maxVec = LM.Vector2:new_local()
-- The guts of this script
function LM_ScalePoints:IsEnabled(moho)
	if (moho:CountSelectedPoints() > 1) then
		return true
	end
	return false
end
function LM_ScalePoints:OnMouseDown(moho, mouseEvent)
	local mesh = moho:Mesh()
	if (mesh == nil) then
		return
	end
	mesh:SelectedBounds(self.minVec, self.maxVec)
	self.centerVec = (self.minVec + self.maxVec) / 2
	-- First step - figure out which scaling handle is being dragged
	self.scalingDir = -1
	local boxW = (self.maxVec.x - self.minVec.x) / 2
	local boxH = (self.maxVec.y - self.minVec.y) / 2
	dx = mouseEvent.vec.x - self.centerVec.x
	dx = math.abs(dx)
	dy = mouseEvent.vec.y - self.centerVec.y
	dy = math.abs(dy)
	if ((dx > 0.8 * boxW) and (dx < 1.2 * boxW)) then
		if ((dy > 0.8 * boxH) and (dy < 1.2 * boxH)) then
			self.scalingDir = 2
		elseif (dy < 0.2 * boxH) then
			self.scalingDir = 0
		end
	elseif (dx < 0.2 * boxW) then
			self.scalingDir = 1
		end
	end
	if ((self.scalingDir < 0) and (dx > 0.8 * boxW) and (dy > 0.8 * boxH)) then
		self.scalingDir = 2
	end
	if (self.scalingDir < 0) then
		return
	end
	moho.document:PrepUndo(moho.layer)
	moho.document:SetDirty()
	mesh:PrepMovePoints()
	self.selID = -1
	self.selList = MOHO.SelectedPointList(mesh)
	self.numSel = table.getn(self.selList)
	if (self.numSel < 2) then -- work with only the closest selection
		-- find the closest point here
		self.selID = mesh:ClosestPoint(mouseEvent.startVec)
		if (self.selID >= 0) then
			self.numSel = 1
			mesh:SelectNone()
			local pt = mesh:Point(self.selID)
			pt.fSelected = true
			if (pt.fWidth.value < 0) then
				pt.fWidth:SetValue(moho.frame, 0)
			end
			pt.fTempWidth = pt.fWidth.value
			moho:UpdateSelectedChannels()
		end
		self:UpdateWidgets(moho)
	end
	for i, pt in self.selList do
		end
	end
	mouseEvent.view:DrawMe()
end
function LM_ScalePoints:OnMouseMoved(moho, mouseEvent)
		return
	end
		return
	end
	local scaling = LM.Vector2:new_local()
	scaling:Set(1, 1)
	-- scaling connected to actual drag amount
	local v1 = mouseEvent.startVec - self.centerVec
	local v2 = mouseEvent.vec - self.centerVec
	scaling.x = v2.x / v1.x
	scaling.y = v2.y / v1.y
	if (self.scalingDir == 0) then
		scaling.y = 1
		if (mouseEvent.altKey) then
			scaling.y = 1 / scaling.x
		end
	elseif (self.scalingDir == 1) then
		scaling.x = 1
			scaling.x = 1 / scaling.y
		end
	else
		scaling.x = (scaling.x + scaling.y) / 2
		scaling.y = scaling.x
	end
	mesh:ScalePoints(scaling.x, scaling.y, self.centerVec)
	moho:AddPointKeyframe(moho.frame)
	local offset = (math.abs(scaling.x) + math.abs(scaling.y))/2
	local maxWidth = moho:PixelToDoc(64)
	if (self.numSel == 1) then
		pt.fWidth.value = pt.fTempWidth * offset
		pt.fWidth.value = LM.Clamp(pt.fWidth.value, 0, maxWidth)
		pt.fWidth:StoreValue()
	else
		end
	end
end
function LM_ScalePoints:OnMouseUp(moho, mouseEvent)
		return
	end
		return
	end
		-- update the selected list
	end
	-- clear out NULL width key values if there is more than one keyframe
		if (pt.fWidth:CountKeys() > 1) then
			for id = pt.fWidth:CountKeys() - 1, 0, -1 do
				local when = pt.fWidth:GetKeyWhen(id)
				if (pt.fWidth:GetValue(when) < 0) then
					pt.fWidth:DeleteKey(when)
				end
			end
			if (pt.fWidth:CountKeys() < 1) then
				pt.fWidth:SetValue(0, -1)
			end
		end
	end
	self.selList = nil
	moho.layer:UpdateCurFrame()
	moho:NewKeyframe(CHANNEL_WIDTH)
	moho:NewKeyframe(CHANNEL_POINT)
end
function LM_ScalePoints:OnKeyDown(moho, keyEvent)
	LM_SelectPoints:OnKeyDown(moho, keyEvent)
end
function LM_ScalePoints:DrawMe(moho, view)
		return
	end
	local g = view:Graphics()
	local min = LM.Vector2:new_local()
	local max = LM.Vector2:new_local()
	local markerR = 4
	local matrix = LM.Matrix:new_local()
	mesh:SelectedBounds(min, max)
	moho.layer:GetFullTransform(moho.frame, matrix, moho.document)
	g:Push()
	g:ApplyMatrix(matrix)
	g:SetColor(255, 0, 0)
	g:SetSmoothing(true)
	g:DrawLine(min.x, min.y, max.x, min.y)
	g:DrawLine(min.x, max.y, max.x, max.y)
	g:DrawLine(min.x, min.y, min.x, max.y)
	g:DrawLine(max.x, min.y, max.x, max.y)
	g:SetSmoothing(false)
	g:DrawFatMarker(min.x, min.y, markerR)
	g:DrawFatMarker(min.x, max.y, markerR)
	g:DrawFatMarker(max.x, min.y, markerR)
	g:DrawFatMarker(max.x, max.y, markerR)
	g:DrawFatMarker((min.x + max.x) / 2, min.y, markerR)
	g:DrawFatMarker((min.x + max.x) / 2, max.y, markerR)
	g:DrawFatMarker(min.x, (min.y + max.y) / 2, markerR)
	g:DrawFatMarker(max.x, (min.y + max.y) / 2, markerR)
	g:Pop()
end
-- Tool options - create and respond to tool's UI
LM_ScalePoints.DUMMY = MOHO.MSG_BASE
LM_ScalePoints.MODIFY = MOHO.MSG_BASE + 1
LM_ScalePoints.RESET = MOHO.MSG_BASE + 2
LM_ScalePoints.SELECTITEM = MOHO.MSG_BASE + 3
function LM_ScalePoints:DoLayout(moho, layout)
	self.menu = LM.GUI.Menu(MOHO.Localize(self.BASE_STR + 2, "Select Group"))
	self.popup = LM.GUI.PopupMenu(128, false)
	self.popup:SetMenu(self.menu)
	layout:AddChild(self.popup)
	layout:AddChild(LM.GUI.StaticText(MOHO.Localize(self.BASE_STR + 3, "Scale")))
	layout:AddChild(LM.GUI.StaticText(MOHO.Localize(MOHO.STR_X, "X:")))
	self.scaleX = LM.GUI.TextControl(0, "00.0000", 0, LM.GUI.FIELD_FLOAT)
	layout:AddChild(self.scaleX)
	layout:AddChild(LM.GUI.StaticText(MOHO.Localize(MOHO.STR_Y, "Y:")))
	self.scaleY = LM.GUI.TextControl(0, "00.0000", 0, LM.GUI.FIELD_FLOAT)
	layout:AddChild(self.scaleY)
	layout:AddChild(LM.GUI.Button(MOHO.Localize(self.BASE_STR + 4, "Modify"), self.MODIFY))
	layout:AddChild(LM.GUI.Button(MOHO.Localize(MOHO.STR_RESET, "Reset"), self.RESET))
end
function LM_ScalePoints:UpdateWidgets(moho)
		return
	end
	MOHO.BuildGroupMenu(self.menu, mesh, self.SELECTITEM, self.DUMMY)
	self.scaleX:SetValue(1)
	self.scaleY:SetValue(1)
end
function LM_ScalePoints:HandleMessage(moho, view, msg)
		return
	end
	if (msg == self.MODIFY) then
		local centerVec = mesh:SelectedCenter()
		local scaleX = self.scaleX:FloatValue()
		local scaleY = self.scaleY:FloatValue()
		mesh:ScalePoints(scaleX, scaleY, centerVec)
	elseif (msg == self.RESET) then
		if (moho.frame > 0) then
			for i = 0, mesh:CountPoints() - 1 do
				local pt = mesh:Point(i)
				if (pt.fSelected) then
					pt:SetPos(pt.fAnimPos:GetValue(0), moho.frame)
				end
			end
		end
	elseif (msg >= self.SELECTITEM) then
		mesh:SelectNone()
		local i = msg - self.SELECTITEM
		local name = mesh:Group(i):Name()
		mesh:SelectGroup(name)
		moho:UpdateUI()
	end
end
