Peak/smooth problem
Posted: Sat Jan 15, 2011 3:59 am
Hi
I've started experience a prob with my curves yesterday.
I was working on a drawing when I started a curve with the "Add point" tool.
I clicked the first point, and when i clicked the second it became imediately curve. I completed the process adding all the points and at the end I selected them all and chose draw-peak.
Nothing happened.
Tried several times without succes.
I decided to create a new document. Now peak was working perfectly.
I copied the shape to take it to the previous drawing. There, peak was not working again.
In this same drawing, sometimes creating a new layer worked. I could draw a shape with sharp corners. But suddenly, even draing on new layers was resulting in a smooth shape (I needed sharp, and peak wouldn't work).
I could immediately gues if I was going to have a prob. If on the second point added I'd see it curved, I knew "peak" or "smooth" commands wouldn't work.
I could either try to buid the shape in a new layer or, if it didn't work, close de document, create a new one, draw the curve there, copy it, close it, go back to the document I was working on and paste it there.
Am I missing something here?
Thanks in advance.
Nothing happened.
Thanks in advance.
