PRO 7 ~ Weld Points Remove Fill Color!
Posted: Thu Dec 02, 2010 3:22 pm
I am trying to weld 2 shapes together, similar to Tutorial 2.1...
This is NOTHING like the example of the two welded circles on page 20 of the manual.
Trying the *recommended* method of welding two shapes together by removing the the bottom half of the oval (2 curves), and then welding the endpoints to the second shape leaves you with a "dead curve shape," that you CANNOT fill by any means. The Select Shape Tool will only activate the box.
Although you CAN change the stroke width and color of the now open ended oval curve, you cannot get the shape to return with a fill color, similar to the example "Welding the new end points" on Pg. 26 of the manual...
I am following the manual instructions as printed, but am NOT getting the promised results...
Could someone PLEASE tell me what I am doing wrong, here? I think it's a bug, but could very well be mistaken (and hope I am!)
Thanks!
- Drawing 2 shapes ~ Shape 1, a blue box and Shape 2, a white oval.
- Select the Transform Points Tool, uncheck Auto-weld.
- Click on the white oval, and position one end point of the oval over the top corner of the box.
- Click on the point to select just that point, rather than all the curve points of the oval, and hit the spacebar to weld the point.
Thanks!
