How to key all bones at one touch?
Posted: Tue Nov 23, 2010 1:42 pm
by Animark
Hello,
I like to know if there is a way (maybe a script/tool) to get keys for all bones inside one bonelayer with one (or two) clicks.
At the moment I touch bone after bone with one bonetool to get the keys.
Another way is to make keyframes by hand on the timeline after selecting every bone.
Thats drives me away from concentrate on my animations and there must be a better way.
I've tested the All-In-One Bone Tool, which works fine, but made some problems, I described in that topic.
It would be very helpful to get an idea or a hint how to key all bones with one click :-).
Thanks from Animark
Posted: Tue Nov 23, 2010 2:05 pm
by Víctor Paredes
Key Skeleton wrote by Mkelley works very fine for me. It's a button, so I assigned it the Y key. It's fantastic, one of my must have.
you can read about it here
http://www.kelleytown.com/forum/animato ... PIC_ID=194
And here you have a link to download
http://www.mediafire.com/?wyf52pbrubqk4bt
Posted: Tue Nov 23, 2010 3:33 pm
by Animark
Hi Selgin,
that tool is exactly what I was looking for. Thanks for that hint. It was a little bit picky to install it as a button - it was the first time I did - but now it works. I've found the install tutorial at the kelleytown forum.
By the way, I've shown the machi-film to my students. They liked it and got good inspirations for what is possible to animate in ASP and is not vector-style. Thanks again for that too :-)
Posted: Tue Nov 23, 2010 3:54 pm
by Víctor Paredes
Nice to help you, Animark. That script is great and I try to promote each time there is an oportunity :roll:
You have been very nice on showing that short to your students, thank you and I'm glad they liked it.
Maybe I could send you some anme files of a couple characters so your student could see how they are made.
Posted: Tue Nov 23, 2010 7:10 pm
Hm, I use to select all bones (apple-a) in a bone layer and then click with the rotate or transition tool somewhere, this creates keys for all of them as well.
Posted: Tue Nov 23, 2010 7:13 pm
by Víctor Paredes
slowtiger wrote:Hm, I use to select all bones (apple-a) in a bone layer and then click with the rotate or transition tool somewhere, this creates keys for all of them as well.
This tool make keyframes for rotation, translation and scale, so you get keys for all the skeleton movements really fast. It's nice too when you are using pen instead mouse, because with pen it is harder to click without moving anything.
Posted: Tue Nov 23, 2010 10:38 pm
by Axlen
I had a little trouble adding the key skeleton script at first, but after a little searching I found the answer. (MK_key_skeleton.lua, MK_key_skeleton.png)
The script and icon file get installed in the tools directory of course, but in addition the _tool_list.txt file needs to be edited.
Add a line like this at the end or where ever you want the button icon to appear on the tool palette.
(C:\Program Files (x86)\Smith Micro\Anime Studio Pro 6\scripts\tool\_tool_list.txt)
button	MK_key_skeleton		K
In my copy of the file a I added a tool palette for Kelleytoons.
group MOHO.Localize("/Tools/Group/Kelleytoons=Kelleytoons")
Mike Kelley's Key Skeleton script is actually a menu script, and you could install it that way it you wanted to, but because of the difficulty assigning hot keys to menu scripts an alternative is to install it in the tools folder and assign a key to it. Clicking on the icon does nothing. To make it work you have to enable it as a button that is assigned to a key. Mike suggests the K key.
Posted: Wed Nov 24, 2010 3:15 am
by neeters_guy
This is a must have tool. One thing to note is that this tool won't key bones in any sublayers, only on the top level bone layer.
