Page 1 of 3
New Camera Tool: Point Camera [*new version 6 *]
Posted: Tue Sep 21, 2010 1:36 pm
by Peteroid
*** UPDATE : There is now a version 6 with more functionality ***
What it does: This tool allows the user to select a Layer and a Frame Range... when executed the camera will always look directly at the layer for the entirety of the frame range.
The way it works:
- Select a Layer (vector layers should work, others not sure - beta- )
- Select Point Camera in Tools
- Enter desired Frame Range in Toolbar area at top of screen
- Hit Execute
Things it DOES NOT CHANGE: camera position, layer position, camera zoom
Note the camera and layer may move around during this in any pattern!!!
WARNINGS: there are three cases that are prone to problems. When the layer and camera are at same point. In this case Point Camera does not add a keyframe, and leaves the frame alone. The other two cases occur when the layer is directly overhead or directly underneath the camera. This is dangerous, because panning just looks like rolling. It will still create a keyframe here though, and leave pan alone.
A PICTURE IS WORTH A THOUSAND WORDS (or in this case, two videos):
TUTORIAL 5.8.
BEFORE:
http://www.youtube.com/watch?v=qTI_gqJhDrk
AFTER: (pointing at Tree 7 for entire animaton).
http://www.youtube.com/watch?v=2YkazxgpsjQ
Installation files: http://www.peteroid.com/share/pao_point_camera.zip
unzip. Add pao_point_camera.lua and the two image files to the 'tool' folder under the AS folder.
There are now two versions included. 'pao_point_camera.lua' works for me in ASP7. 'pao_point_camera_AS5.lua' is an attempt to get it to work in AS5... I don't have AS5 so I can't test it. [UPDATE: tested and works]
If using the AS5 version, be sure to change the name of the file 'pao_point_camera_AS5.lau' to 'pao_point_camera.lua' before putting it in 'tool'.
Then you may update your '_tool_list' to be 'similar' to the EXAMPLE I've include. The one I included, if you just copy it and paste (the contents, it must still be named '_tool_list' in the 'tool' folder), it WILL work, but will remove the ability to use any other tools you might have custom installed in the past. Don't fool with this unless you really know what your doing.... (so how the hell did I manage...lol)...
You can skip the above '_tool_list' step, it just means the Tool will appear in the 'Other' Tool section and not in the Camera Tool section.
I have not yet tested with anything but exactly one layer selected. I don't know what happens yet if the layer is not a vector layer.
So I still have to do error processing, if any.
Right now it will do this for frame 0 (is that ok?)
As a kind or added feature, if start > end then it just does the two end points (it will then tween between instead of being perfect). if start = end it just does that frame.
I have in mind MANY techniques that this can be used for. I'll post those in the future. but I want to test what I have first!
Let me know what you think! :)
UPDATE: [*new version 5*]
New version allows reversal of camera and to adjust the location the camera is focusing on by an (dx,dy,dz) delta vector.
UPDATE: [*new version 6*]
Added 'Use Parents'. When this is checked the position of the Layer takes into account any effects by the Parent[s]. Thus, it is the trues spacial location in the 3D world. Typically, this option will be set to true.
PS - I have also added this feature to my other camera tools, so get new versions (I tend to improve them on occasion without notice...hehe).
Posted: Tue Sep 21, 2010 2:52 pm
by funksmaname
yay! you finally got there...
I'll give it a test soon as I get some time!
congrats on your first script :)
Posted: Tue Sep 21, 2010 2:55 pm
by ulrik
Hi!
This looks very interesting, I looked at your videos and indeed I can see that this script could be useful!
Thnaks a lot for this! :D
Posted: Tue Sep 21, 2010 7:59 pm
by Peteroid
funksmaname wrote:yay! you finally got there...
Thanks! :)
Posted: Wed Sep 22, 2010 2:17 am
by patricia3d
Thanks for your developments.
Will this work with 6.2?
Posted: Wed Sep 22, 2010 3:45 am
by Genete
Congratulations Peter!
Posted: Wed Sep 22, 2010 8:07 am
by VĂ­ctor Paredes
works great, Peteroid. Thank you very much. It's fantastic to have a new scripter on forum :D
Posted: Wed Sep 22, 2010 8:41 am
by Peteroid
selgin wrote:works great, Peteroid. Thank you very much. It's fantastic to have a new scripter on forum :D
Thanks!
BTW... sorry to be so much of a pain in the ass when I was learning... now that I have my 'foot in the door' I should be more relaxed...
I get a bit TOO passionate about programming sometimes... hehe :)
Posted: Wed Sep 22, 2010 1:58 pm
by funksmaname
an idea:
Is there a way to keep the camera equidistant to the layer? at the moment having the camera pan around a layer that moved from left to right, and setting the layer to 'face camera' results in no rotation for the layer or position translation - which is cool, but it enlarges and shrinks presumably as the layer flies past the camera... is there a way to make the camera move back as the object approaches it and return once it passes so it 'looks' like there's no camera movement at all? (probably a checkbox rather than baked feature) :P
Posted: Wed Sep 22, 2010 2:14 pm
by Genete
funksmaname wrote:Hey there,
I'm a little confused... maybe i'm using it wrong?
I created a circle and had it move with layer translation from one side to the other... i then ran the script to point the camera, expecting the circle to effecively stay still but it sort of just turned slightly away from me in shame... sorry if i'm being a dumbass.
You have to move the camera and the script will fix the pan and tilt values to point always to the current selected layer. I don't know if it works for moving layers but it shouldn't be a problem.
Posted: Wed Sep 22, 2010 2:16 pm
by funksmaname
Thanks genete - but sorry, i deleted my previous post as i was using v1 of the script, v2 works more as expected :) (the problem had been i changed the layer origin) - you're too quick for your own good! ;)
Posted: Wed Sep 22, 2010 4:13 pm
by DK
Confirmed latest version works in AS 5
Cheers
D.K
Posted: Wed Sep 22, 2010 6:04 pm
by Peteroid
funksmaname wrote:an idea:
Indeed, I also think it would be cool for it to preserve visual distance.
This will take a bit if investigation, since I would need a PERFECT formula that converts zoom to 'effective distance', and this might not be possible since 'zoom' introduces visual distortion effects. Better to just move the camera itself to the desired visual distance!
And, here's the thing. This would no longer permit the camera to APPEAR to move on an 'arbitrary' path.
If the layer always looks like it is the same distance, then this is equivalent to restricting the camera to a circle of the desired visual distance. Thus, to accomplish, one need only put the camera a circular path and move it around (and apply Point Camera to force it keep looking at object).
I think most everyone, like me, is using Tutorial 5.8 as a means to test. This tutorial was not made with Point Camera in mind. To prevent this 'getting closer' and getting farther' look, just keep the camera the same distance from layer!
And THAT is a tool I might build. It would do this.... give it a frame range and a distance. When applied, the camera is moved to a position exactly equal to the distance supplied along the same line that connects the camera position and the layer (in this case, preserving tilt and pan).
Now, if you apply BOTH scripts you get the effect you asked for... but remember it will end up just moving the camera on a circular path around the layer. But this will be relative to the layers motion, so the camera will stay on a 'hoop' about the layer no matter where the layer goes!
Posted: Wed Sep 22, 2010 6:13 pm
by Peteroid
It keeps the origin of the layer in the center of the screen. But that doesn't mean the layer won't turn away from you.... it will!
Consider this. You stand in front of a friend and face directly at him. Now start to move in a circle around him while still facing his direction, and you will see him turn so his side is now in front of you! Continue and you see his back, then his other side, then his front again. So, from YOUR pov, he stay's in the center of your view and he turns away from you!
In other words, this does not move the camera, it points it at the layer, Thus, you can see it from any side.
It might be interesting for me to write a tool that keeps not only the origin in the center, but the layer at a perpendicular angle. But note this requires moving the cameras position, something PointCamera does not do (on purpose)...
Posted: Wed Sep 22, 2010 7:30 pm
by funksmaname
well, there's 3 empty spaces next to your point camera tool that are waiting to be filled...
how about 'dolly on target' - we could have a non rendering camera target layer...
My main issue is i don't want things warping really - since this is 2D animation, i want all planes to be always perpandicular to the camera rather than skewed in 3D... :)
maybe if we had the same tool as you already have but have it do the move instead of tilt, and we could run both tools if we want both functions? then we could control zoom manually on top of those keys? *shrug* thinking on my feet here, i've not really used camera moves much until recently, and then for some reason the zoom/move weren't happening at the same time, so i was getting odd camera moves... possibly just me being rubbish :D
