have a look ...
Posted: Wed May 18, 2005 1:28 pm
by mel
i cant understand why , when the swf plays a second time i still can see the first path immobile..
see:
http://melanie.ferber.free.fr/url_forum ... %20SON.swf
any idea?
Posted: Wed May 18, 2005 1:32 pm
by Sevenmile
Huh... weird... I've no idea :?
Can you post the mohofile, please?
/Jacob
Posted: Wed May 18, 2005 2:05 pm
by mel
yep ;p
http://melanie.ferber.free.fr/url_forum ... iroir.moho
the strange thing is that ive done other sheep like that , but only the black one has that bug...
help pliz'
Posted: Wed May 18, 2005 2:10 pm
by BA
the same thing happens to me virtually every time I export to .swf.....
Try clicking on 'add extra swf frame' in project settings, that usually helps with the frozen frame... but I still get weirdness in other ways when exporting to flash.
Posted: Wed May 18, 2005 2:14 pm
by mel
ok ill try tomorrow , for now its time to go to bed ;)
thanks, ill tell you more soon !
i forgot, for me , its 11h15 pm :)
Posted: Wed May 18, 2005 2:15 pm
by Hiddicop
There's nothing wrong when I export it as an swf, so the problem must have occurd during rendering. The swf-file you posted was wierd, but the moho-file was okay. I suppose you've tried re-rendering it, so I can't see what's wrong. It's really wierd.
Posted: Thu May 19, 2005 7:25 am
by Sevenmile
Huh... there's nothing wrong when I export it either... I noticed that the filesize of the swf-file you posted was 287 kb compared to mine which was just 120 kb...
Which version of moho do you use? (Help -> About Moho)
/Jacob
Posted: Thu May 19, 2005 12:37 pm
by mel
yep , exactly i only had to reexport the file.. strange.. but now it works perfectly :) i should have done that before alarming averybody !
thanks :!:
Posted: Sat May 21, 2005 11:36 pm
by 7feet
Not really alarming. I rarely use the flash export, but sometimes I have something thaTs pure vector and needs to be small. Usually an example of how a particular bit of an animatronic mechanism would work. I don't really know why it happens on some, but I've had this same problem often. Extra frame, no extra frame, who knows, sometimes it just doesn't loop right and you get the end of the last frame sitting on top of everything for the rest of the passes. Maybe a bug in Ming (the lib Moho uses for flash export) or the way Moho is inerfacing to it. Dunno, but I would probably use it more if that didn't happen.
