Oops... drew on frame OTHER than frame 0
Posted: Sun Aug 08, 2010 11:27 am
by Ryder
Hi all,
made the mistake of creating something on a frame other than zero.
I have heard rumors that such a problem can be corrected... help!
(some kind of copy > paste to frame zero)
Thanks!
Ryder
Posted: Sun Aug 08, 2010 12:03 pm
by ulrik
Yes copy and paste, you should stand on frame zero and then select the frames where you accidentily create something, copy from above the timeline, not from the meny, and paste and it should be okay. Then you can delete the selected keyframes.
Posted: Sun Aug 08, 2010 12:13 pm
by Ryder
ulrik wrote:Yes copy and paste, you should stand on frame zero and then select the frames where you accidentily create something, copy from above the timeline, not from the meny, and paste and it should be okay. Then you can delete the selected keyframes.
OK, I am missing something...
I have an object on frame 6
I have set the slider to frame 0
You now say "select the frames". I don't know what that means.
Thanks for the assist!
Posted: Sun Aug 08, 2010 12:44 pm
by sbtamu
What ulrik is saying is set the time line to zero, then drag the mouse over the keyframe/s while holding the left mouse button down so they are red, then hit the copy button right above the time line then hit paste.
Stephen
Posted: Sun Aug 08, 2010 12:52 pm
by Ryder
sbtamu wrote:What ulrik is saying is set the time line to zero, then drag the mouse over the keyframe/s while holding the left mouse button down so they are red, then hit the copy button right above the time line then hit paste.
Stephen
Got it....! Thanks to you both.
