Masking issue, clear mask, then add.
Posted: Mon May 02, 2005 12:31 pm
by rylleman
When setting a mask to "Clear the mask, then add this layer to it", is there a way to have this mask invisible? It's visible by default and if I turn off visibility or choose "Don't render this layer" the mask effect is lost.
Posted: Mon May 02, 2005 1:16 pm
by Hiddicop
What I do is to create an extra, empty layer under the mask and on this layer I choose "Clear the mask, and the add this layer to it". On the mask-layer (not the new one) set the masking to "Add to mask, but keep invisible". Then it should work.
Posted: Mon May 02, 2005 1:50 pm
by rylleman
That's a workaround I can use, thank you.
