Page 1 of 2
The town crier
Posted: Fri Feb 26, 2010 12:46 am
by Uolter
Here's a character I'm working on. All comments are welcome!
http://www.youtube.com/watch?v=KhiHxNvIa_w
Posted: Fri Feb 26, 2010 1:43 am
by aleXean
oOo I really like how the legs were rigged on this character... any secret?
Posted: Fri Feb 26, 2010 2:04 am
by Víctor Paredes
aleXean wrote:oOo I really like how the legs were rigged on this character... any secret?
Maybe hi is using Mandcon arm/leg rig. It's the best and simplest arm rigging I have seen so far is on. You can see it on
this thread, there you will find
this file.
Since I downloaded it I always use his technique.
Obviously the credits are for
mandcon.
Posted: Fri Feb 26, 2010 2:06 am
by Uolter
well...no secrets, I am learning and this is how I supposed to work...what do you want to know exactly? Glad If could help
Posted: Fri Feb 26, 2010 2:25 am
by Víctor Paredes
Nice test, by the way.
I like the rithm of the walk.
Posted: Fri Feb 26, 2010 2:30 am
by Uolter
I used a different rigging, but thank you for showing this, could be very useful. Here's how i worked:
The leg is on two layers. The upper leg ends with a circle shape and the lower is right-angled. The point of rotation is set on the centre of the circle. Then I used gradients and hide edge tool...that's all!
Posted: Fri Feb 26, 2010 2:41 am
by Uolter
Thank you Selgin!
here's a screenshot of the setup:
Posted: Fri Feb 26, 2010 3:28 am
by super8mm
Nice walk cycle.
Posted: Fri Feb 26, 2010 3:35 am
by aleXean
I love Mandcon's rig, just couldn't tell if that was how his legs were rigged.
Posted: Fri Feb 26, 2010 12:23 pm
by Uolter
super8mm wrote:Nice walk cycle.
Thank you super8!
Posted: Sat Feb 27, 2010 12:12 pm
by AmigaMan
Great walk. I like the rotation you put on the upper body. Makes all the difference doesn't it
It also has some weight to it that a lot of animated walks don't.
Posted: Sat Feb 27, 2010 2:42 pm
by super8mm
AmigaMan wrote:Great walk. I like the rotation you put on the upper body. Makes all the difference doesn't it
And yet all the rotation is are the arm's joints are displaced from front to back. You can't squash and stretch with AS but at least with the stretch part you got the weight.
Posted: Sat Feb 27, 2010 3:12 pm
by AmigaMan
Yes, translating the arms makes it appear the chest is rotating??
What do you mean "you can't squash and stretch with AS"? Of course you can. You just scale the bone that has the body part bound to it you want to squash/stretch. I do it all the time.
Posted: Sat Feb 27, 2010 3:25 pm
by Uolter
Thanks Dale for the comment! Actually I squashed and stretched the entire figure a bit with the scale layer tool (holding alt) the only problem is that the megaphone squashed and stretched too...
Posted: Sat Feb 27, 2010 3:29 pm
by AmigaMan
I noticed you'd squashed the whole figure. You might be better just squashing (scaling) the character bones which will avoid the problem of the megaphone squashing.
