Moho 5.1.1 Illustrator Import
Posted: Thu Apr 21, 2005 3:41 am
by Toontoonz
* Improved Illustrator import - better interpretation of line widths and CMYK color
I did a couple of brief tests. The line width seems improved - ecspecially finer line widths.
When I add one set of additional anchor points in Illustrator (double the number it had when I drew it) the shapes match near perfect in Moho. If I don“t add the additonal anchor points in Illustrator their are issues with some curves.
Regarding color, here is a comparison between the Illustrator RGB file and the Moho colors:
Pink/Lila color:
Illustrator (RGB): 251, 174, 255
Moho (RGB): 249, 172, 255
Yellow color
Illustrator (RGB): 254, 222, 88
Moho (RGB): 246, 225, 92
Green color
Illustrator (RGB): 204, 255, 66
Moho (RGB): 203, 255, 55
Posted: Thu Apr 21, 2005 4:19 am
by Toontoonz
Colors from an Illustrator CMYK file imported into Moho:
Green color:
Illustrator (CMYK/RGB): 115, 192, 62
Moho (RGB): 114, 255, 40
Orange color:
Illustrator (CMYK/RGB): 237, 179, 41
Moho (RGB): 237, 181, 46
Pink color:
Illustrator (CMYK/RGB): 248, 89, 130
Moho (RGB): 255, 86, 193
Posted: Thu May 05, 2005 12:23 am
by tim worsfold
Yes, I've had similar problems on the Mac version, but oddly enough the other day I imported something and all the colours were perfect! OK it was black, white and yellow but it worked! I have no idea how I did it though: it was probably a fluke.
I've also noticed that Illustrator import is much slower in version 5.1 compared to 5.0 - even a simple file takes about a minute to import.
