HUGE problems with exporting animation
Posted: Mon Sep 28, 2009 4:24 am
Hi,
When I render an individual image from my animation, the colour is perfect in the JPG. It's as I would expect.
#1
When exporting as Quicktime > MPEG4 > "best" quality, everything is far too pale - the skin colour of my characters goes from being a light pink to a horrible pale yellow colour.
#2
When exporting as Quicktime > tick "NTSC Safe" colouring > "best" quality, everything looks more like it should.
#3
When exporting as Quicktime > H.264 > untick "keyframe every x frames" (if I don't do this, only 1 frame of the animation will be saved in the output file), everything looks as expected.
My issues are when using method #2, the NTSC safe colouring only applies to the first file saved - so the first movie in the batch has the correct colours then everything rendered after this are the horrible pale colour again.
Using method #3, once again, only the first file is saved correctly - anything rendered after the first file in the batch will only have 1 frame saved in the animation.
ALL I WANT TO DO IS BE ABLE TO BATCH RENDER MY ANIMATION (90+ SCENES) WITH THE CORRECT COLOURS! THIS SHOULD NOT BE SO DIFFICULT!!!
Does anybody have any suggestions?
Thanks
#1
#2
#3
Thanks
