some feature requests
Posted: Fri Jul 17, 2009 6:15 am
1. To be able to have the "Blend Morphs" window open all the time, and if you push the "Ok" button it will insert the keys but the window will stay open, this in conjunction with be able to step forward and backward in timeline (as usual) while the BM window is open. This would be a great improvment I think!
2. An option to insert "last inserted keyframes". If you've inserted an action which includes several keys at different layers and you want to hold this pose for 7 frames, then it's very time consuming to find all this keyed layers and insert them again at another frame, it would be great to be able to step forward 7 frames and use this "Insert last inserted keyframes" again, I know you can do it with the script: "Key all" but maybe I don't want to key all channels at this point, I just want to key the last keyed channels.
When working with "Blend Morphs" this would increase the speed a lot.
