FLA files
Posted: Sun Jun 28, 2009 8:25 pm
by Damster25
I want to submit my animation to newgrounds and it says my chances of getting on the are higher if I include a preloader. I have the FLA preloader files, but i don't know how to get them into anime studio.
Please Help me. :?
Posted: Sun Jun 28, 2009 8:44 pm
by Damster25
also, the soundtrack dosen't work whn i export as a SWF but works as an AVI
Posted: Sun Jun 28, 2009 10:53 pm
by Tom_E
Sorry but Flash files of any type (FLA or SWF) cannot be imported into Anime Studio. You would have to export what you need from AS as a SWF file and import it into Flash and use Flash to put everything together with the preloader.
As for the soundtrack, when exporting from AS I believe it has to be an MP3 for it to be used inside Flash. I'm not entirely sure on that, as I have only exported animations for use in web banners and have not used anything with sounds in it. I believe I read it in the Anime Studio 5.6 documentation (there were tips on exporting your projects for use in Flash).
Thanks.
Posted: Mon Jun 29, 2009 12:56 am
by Damster25
thank you for the info
Posted: Mon Jun 29, 2009 3:59 am
by chucky
you can use swish to compile and make preloader if you have budget issues.
Posted: Mon Jun 29, 2009 5:01 am
by VĂ­ctor Paredes
I have read that to export a flash with sound you must copy your have your wav file and a mp3 with the same name in the same directory. AS will take the avi when you be editing the animation, but when you export, it will take the mp3.
I haven't tried it yet, but if I remember well, this should work.
